Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
My oven will not unlock.
Can you help me unlock it please?
  • 187 Answers
Either unplug or turn the off off at the breaker. It may clear the problem. This happens a lot after clean cycles. Sometimes the electronics fry due to high heat, so try not to use self clean very often.
If this doesn't work, leave comments with your oven model and type of lock if you know. The instructions for opening a stuck lock depend on which type of lock you have: solenoid controlled buzz when setting or unlocking and have an arm you move to engage the lock. Heat sensitive locks have an lever you move to lock and un-lock, but don't make noises. Motorized locks don't have handles or levers, and lock by themselves. Thanks for your question, I hope the first instruction helps.
Posted on May 08, 2010
How do I unlock my gas stove oven?
Thank you for your inquiry, friend!
From the information you have provided you need assistance unlocking your Frigidaire oven. Performing a reset on your oven can trigger the door latch to unlock, in order to reset your oven you would need to disconnect power from it for roughly ten minutes. If this does not unlock your oven you can also hold down the clear or cancel button for 10 to 15 seconds. You can also attempt to perform a self-clean cycle and before the cycle starts cancel it and that can trick your oven into unlocking. If these troubleshooting steps do not help resolve your issue please feel free to reconnect. I would be happy to provide you further assistance. -Matt
Mar 13, 2015 | Frigidaire Ovens
My oven is saying unlock door after self cleaning but the door is open
It's likely that the door switch has failed, or stuck in the depressed position from grease or your oven cleaner spray solution. To correct this problem, remove the door switch and inspect with a multimeter for continuity connection.
Dec 22, 2013 | Ovens
Model 40121 the oven is locked how do i unlock it
Hi!
For unlocking the Kenmore oven, please press and hold the STOP/CLEAR button for 3 seconds.
Please let me know if it helped
Best regards!
Aug 09, 2011 | Kenmore 40192 / 40199 Electric Single Oven
Key pad is locked how do I unlock
Hi
To unlock the keypad in your GE Oven press and hold the "0" and "9" buttons for 15 seconds. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE JKP45 Electric Double Oven
The oven is locked. What do I push to unlock it?
Hello, Thank You for using FixYa. I will be helping you today.Try to unplug the unit or shut off the breaker for a minute and see if it unlocks
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 07, 2011 | Dacor Ovens
The oven door locked and will not unlock. Was in prpcess of starting to clean oven when door locked by itself and would not unlock or start cleaning process.
Hello, Thank You for using FixYa. I will be helping you today.Try unplugging the unit or turning power off for five minutes and see if it unlocks.The lock cycles when power is turned off and back on.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Kenmore Ovens
Baking, oven beeps and flashing F2 on readout, what does this mean?
Hello, Thank You for using FixYa. I will be helping you today. F2 means temp exceeds 590 with door unlocked or interference with sensor.Most likely a bad oven sensor..I would replace oven sensor.
Jun 17, 2011 | GE JKP15 Electric Single Oven
Used the self cleaning cycle 24 hrs. ago, but the oven door will not unlock. We tried to run it through another clean cycle but we recieve an E1 error.
Sorry to read about your problem, I hope this helps you out.
you may have done a panel lock, so try the first solution.
To Lock/Unlock Control: Before locking, make sure the ovens, Timer and Timed Cooking are off. Press and hold START/ENTER until a single tone sounds and "Loc," a picture of a lock and "START?" will appear on the oven display, about 5 seconds. Repeat to unlock and remove "Loc" from display.
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Whirlpool RBD245PDS Electric Double Oven
Kenmore oven 40494,or40495,or40499
hold the lock button for like 1 minute it should unlock
Jul 17, 2008 | Ovens
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
405 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
