Question about Garden
I have bought a new ryobi reel easy head (LTA 042) and cannot manage to get it to stay on the end of the strimmer. The instructions are not real clear
2 Suggested Answers
SOURCE: I have a Lawn Hornet
Hi, I have the same machine as you and I also needed to replace the head. I purchased the reel easy head and found out that it does not fit the lawn hornet because the head has a tapered end and it does not provide enough clearance against the bushing housing. I did eventually get it to fit but I had to spend a while machining the housing on a lathe. It's a great head and worth the effort but it is very difficult to fit. Cheers
Posted on Mar 11, 2011
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
The pull cord on my Roybi rtl30ces will not retract. How do I access to repair?
Hi Kathy - more likely than not there's a little "tab" on the end of the spring that slips it to a tab in the plastic to maintain spring tension.
These break off fairly regularly and you can easily bend the spring steel to a 90 degree to "fix it" and place it back in the tab.
I've included a teardown / rebuild video that should be very helpful when repairing your weedeater - it's a "generic" ryobi video but they're all really, really similar.
Don't be intimidated - they're super easy to work on! How to Fix the Starter on Ryobi Trimmer
Sep 03, 2016 | Ryobi Garden
I have a Lawn Hornet RLH 1100 Mk II. I have owned it for about 20 years. I need to replace the cutting head and wanted to know if the Reel Easy LTA 042 would be a suitable replacement. John A
Jan 24, 2011 | Garden
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
How much line do I reload a strimmer spool with from a bulk reel?
It depends on the brand of trimmer and the type of head on the trimmer. On my Echo trimmers, I install 18'.
Oct 08, 2009 | Ryobi Garden
I have just bought an RBC30SET. I am trying to
To remove the strimmer and procut fitment first you need to lock the shaft by placing item 35 into the slot in the flange next to the fitment and through into the hole in the outer housing of the drive shaft, item 3. Then using the box spanner turn the fitment CLOCKWISE. Once this has started to move it can be turned by hand until it released. Place the brush cutter onto the shaft followed by the dished washer, cupped face towards the cutter and fix in place with the nut, turning it anticlockwise to tighted. DO NOT overtighted as the direction the cutter turns will tighten the nut further.
Sep 18, 2009 | Ryobi Garden
How to remove old string reel from ryobi 105r
After you line up the two triangles, push in and lift. Only the top piece will come off, then the spool is inside. I kept trying to lift the whole head and then the top popped off and I realized what I was doing wrong. It is actually quite easy once you figure out the correct way and where to pull.
Jul 10, 2009 | Garden
GL 315 strimmer chops the line up into small pieces and goes through a reel in minutes
the spool control teeth have worn out and is continuesly feeding line take out spool look at teeth in head if good replace spool if not need new head and spool
Jul 07, 2009 | Garden
Screw cap to reel head of ryobi ss30 weed eater will not come off
The spool retainer nut loosens when you turn it clockwise . The opposite of " normal ".
Apr 05, 2009 | Garden
Which reel for trimming
Your instruction supplied with your trimmer gives you the information you need. It will recommend which size string to use. Both reels should use the same string.
Nov 30, 2008 | Ryobi Garden
Garden Logo
341 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
