Question about Symphonic SC313D 13 in. TV/VCR Combo
We just bought a used Symphonic 13" TV/VCR. turns on for 3 seconds and shuts off! Help. There's a tape stuck in it also. Help! Thanks, Jay
  • 476 Answers
Hi, a common problem with those combinations is the VCR section, if you are handy with some basic tools you can try a couple of quick procedures, first always make sure you remove the power to the TV, then take the cover off, then look for the carriage belt its usually located to the left of the VCR mechanism looking at it from the back of the TV. With your fingers rotate the cassette mechanism pulley to one side usually counter clockwise untill the tape ejects, this may take awhile because you are doing this manually, but if after a reasonable time the cassette does not eject, try clockwise, once the tape is ejected and out of the cavity, try turning the TV on.
It might be that the belt needs replacing(most of the time this will correct the problem).
Posted on May 08, 2010
  • Symphonic Master
  • 12,061 Answers
Http://www.pechorin.com/m/2006/12/19/Service_Manual-280043.html
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. In any event, this is most likely, a fairly inexpensive repair, but as related ask for a "Quote" before proceeding with any repair.
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
The VCR acts like there is a tape stuck in it, and it makes th TV shut off
unplug the tv,put a tape as far in as you can dont.DO NOT force it in.plug tv back in .turn power on and let it take in the Tape..you might have to help the TV take in the tape
Aug 06, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic vhs tv turns off i hear the vcr after that it turns off
The vcr sistem is out of time and the microprocessor don´t detect the tape is out,you need to change the motor belt charge,good luck
Mar 16, 2009 | Symphonic SC3813 13 in. TV/VCR Combo
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
VCR isn't work, can you help?
Nancy, From the sounds of it either the supply or takeup reel is not working and may be damaged. In fact that may be the reason you couldn't get the tape out... If the takeup reel doesn't spin there is a small sensor below it that recognizes that there is a malfunction and shuts the system down. That's usually far cheaper than unloading a whole tape inside or do some serious damage. This unit is similar in design and electronics as the Funai F3813C and Sylvania 3813LC, W3813LC, Symphonic WS3813C and a Magnavox CCz132. That said, I have worked on a few of the comparable models for something quite similar and it has never been a real expensive repair. i'd guess this one would be under $80 dollars. Just find a reputable shop to take it to... If you not sure where to find one goto: http://www.nesda.com/locator/state_search.php and type in your info. That's the National Electronic Service Dealer's Assn. Kinda like going to the AMA to find a doctor... Good Luck Bill
Jun 07, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Symphonic SC313D 13 in. TV/VCR Combo Logo
268 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
