Question about Electric Chainsaw Sharpener
How do I tighten the blade on a Wen chainsaw?
    President:
  • 2,220 Answers
Hello Gary;
Your OM follows (Wagner/Wen OM):
http://www.wagnerspraytech.com/portal/download.php?src=portal%2Fdownloadcenter%2Fdateien%2Fspraytech%2FDISCONTINUTED_PRODUCT_MANUALS%2FLAWN__GARDEN%2F0505872.pdf&system_id=97280
Download and rename it "AnythingYouLike.pdf" Your question is illustrated on page 4.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 08, 2010
3 Suggested Answers
  • 25 Answers
SOURCE: blade wont tighten on craftsman elictric chainsaw
Sounds like the chain guides are missing.  They're flat steel parts, one on each side of the bar...Here's a husqvarna diagram:
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF  Select side cover, guide plates.  Could be called anything by Craftsman!  If you have one of these on each side of the bar, then I'd guess you're missing washers under the nut(s).  Sears should have this available; I'm sure I have a blow-up diagram on microfische if it's an older model.
Posted on Jul 16, 2009
  • 31 Answers
SOURCE: NEED CHAIN BLADE FOR WEN 2000 10" ELECTRIC
try to this site.. http://shopping.yahoo.com
Posted on Mar 26, 2011
On a k750 wen its running on idle its fine . Soon as you place spinning blade on brick to cut blade stops moveing k750 is 3 week old and been in use for 5 days in 3 weeks. Eny idea plz
Hello Keith, It sounds to me that the drive belt needs to be tightened. There are two bolts between the engine and the blade. Loosen those bolts, tighten the belt and tighten the bolts.
Oct 14, 2015 | Cars & Trucks
The chain keeps slipping off my craftman gas chainsaw
You need to tighten the chain. Loosen the nuts that hold the blade on just a little, then look on the inside of the blade. You will see a screw to tighten the blade. The chain should not be tight. There should be a little space between the chain and the bar. You should not be able to see the guide teeth of the chain. Just about 1/32 of an inch. When you tighten the blade back up, if you had it too lose, it will tighten the chain back to, too tight.
Jun 09, 2014 | Craftsman Garden
Tighten chain on WEN 5041 electric chain shaw?
First loosten that 1/2 bolt on the bar--the lookat the bar when it goes into the housing you will see the adjustment screw.Tighten the chain by turning the screw when you get it to where you want it then tighten the 1/2 inch bolt
Nov 05, 2011 | Electric Chainsaw Sharpener
How do you tighten the blade bolt on skilsaw model 5150? Thw shaft just turns and won't tighten.
There is a button on side that lock blade . Push on button turn blade by hand till you feel button engage now you can tighten bolt left hand threads
Jan 26, 2011 | Garden
Sharpen blade of chain saw
This website explains how to do it...
http://www.ehow.com/video_4419332_sharpen-chainsaw-chain.html
May 11, 2010 | Garden
Sharpening blade of chain saw
The blade needs sharpening when it stops cutting very well. Here is a website to tell you how to sharpen it...
What lubricant oil is used on the blade of a Wen electric chain saw?
I have a Wen 2000 10" electric chainsaw and just ordered a new chain, , but does it need oil poured inside? I have no manual. what kind and how much? can it be over filled, there is a black screw off knob that appears to be for oil?????thanks Kim
Apr 02, 2010 | Electric Chainsaw Sharpener
Need parts for WEN model 6014 chain saw
there are none realy take the two nuts lose take a flate head tighten the chain now if you can pull the chain easy around the bar you good this will give you about a 1/8 in sage on the chain...Good luck
Aug 16, 2009 | Electric Chainsaw Sharpener
Wen electric chainsaw chain gets loose
There is a nut on the rail that the chain runs on. You can loosen it, pry the blade out so chain is snug, than tighten it while you are prying.
Jun 22, 2009 | Heavy Machinery
Electric Chainsaw Sharpener Logo
255 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
