Question about Maytag MDBH985AWW 24 in. Built-in Dishwasher
After the load is done I find pieces of food at the bottom of my dishwasher.
  • 159 Answers
Filter at the bottom of dish washer could be blocked or drain hose blocked remove and clean.
Posted on May 08, 2010
Dishwasher not cleaning properly
There are many reasons why a dishwasher does not work correctly. A repairman told me to always check for debris (food, coins,lids, hard things lost in the dishwasher). You can take the screw off the arm that turns on the bottom level and search under there for anything stuck (even pieces of bone) the dishwasher has several other food filters in the motor assembly but this first one is easy to get to. I would let a repairman fix the motor, but as he said this easy fix is a possibility.
Sep 08, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
I have a GE Nautilus dishwasher. I recently started hearing a clicking noise during my dishwasher cycle. It seems to becoming from behind the access panel on the left hand side of the machine. There are...
The pump/motor assembly on these dishwashers have a soft food cutter that helps to cut up smal soft food particles. This may be your problem.
These cutter blades can sometimes get loose or something can get hung up in them like a broken piece of glass or some other pieces of trash that they can not handle.
You can access these blades by removing the sump cover near the rear of the bottom of the inside of the dishwasher. remove the bottom rack and take a couple of screws out of the sump cover. you can feel down in the sump and see if there is any trash caught up here or in the blades.
If this is not the problem and you have an older dishwasher - you could have a problem with a loose fan blade in the motor. If this is the case I would run it til it dies. The motor/pump assembly is about $125+. The newer motors are a lot quieter.
If everything is working ok. I wouldn't worry too much about it.
Aug 06, 2010 | GE Nautilus 24" Built-in Dishwasher
When my Kenmore 665 dishwasher is done with the cycle, the glasses on the outer areas of the top rack have stuff stuck to them. Almost like the jet spray is clogged and spraying the garbage. My...
I do believe most manufacturers recommend emptying the strainer after each wash (much like you would a lint filter on a clothes dryer). With the door open, look inside on the bottom. You should see a plastic cylinder shape about 2-3" in diameter. Twist it counterclockwise and gently pull up. This traps large pieces of food, and the occasional piece of plastic wrap, toothpicks, etc. that seem to get past the kiddos when they load it. If you find large amounts of food particles, I suggest pre-rinsing pots, pans, plates before placing them in. Good luck, and please keep us informed of the progress on this concern.
Sep 21, 2017 | Kenmore 15129 Built-in Dishwasher
Inside of dishwasher was dirty after cycle, baskets had black in between the screen...took out all bottom and found dirty water, a couple of inches and slime in bottom...cleaned it all out and put it back...
Check the food grinder (small blade spins against a screen) in the bottom of the dish washer drain. I found the grinder to be inoperative and clogged which reduced / stopped flow of the wash water. Also, small pieces of clear plastic food wrap can block flow.
Sep 18, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes on top rack do not come out clean. Bottom rack O.K.
Have you tried cleaning the filter? We had a similar problem. The repair man came and removed all the spinners and the other stuff at the bottom above the motor to get to the filter. It was blocked with all kinds of old food bits and pieces, the odd bit of plastic film etc. He cleaned it, replaced it and we havn't had a problem since but he said it needs to be done about every two years. It can be done by someone who has reasonable DYI skills.
Jan 04, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Smells fishy
You probably have rotting food scraps in the food trap. Take the bottom arm off, remove the filter, and clean. You can also add some bleach to the bottom of the tank and run the dishwasher empty to sanitize the inside. Run a second empty load to rinse. This should help rid the dishwasher of the nasty smell.
Jul 05, 2009 | Dishwashers
Food left in dishwaser
the dishwasher drain line must be elevated above the disposal.
if drain is in proper position check the "p" trap under the sink for a blockage.
Jul 01, 2009 | Dishwashers
Food particles on washed plates
Sometime food particles stick near the door gasket. First, try changing the DW soap brand.
Nov 16, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
Maytag MDBH985AWW 24 in. Built-in Dishwasher Logo
81 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
