Question about Dell Latitude D800 Notebook
Hi Dell D800 won't start up as bar won't go right to the end on first start up screen.
    Scholar:
  • 62 Answers
This is usually a software problem. Drivers are loading during the time that the Windows start up bar is on screen. Try booting the machine and tapping the F8 key. Select 'Safe Mode'. If the system boots up into safe mode, then you have a bad driver. Reboot and tap the F8 key. This time select 'Last known good configuration' See if it boots all the way. If it does, then you should be good to go. If Safe Mode fails to boot, then you need to reload windows.
Posted on May 08, 2010
How to get 2 screens, sise by side on my moniter at the same time
right click on the taskbar(the bar which shows active windows or apps usually below your screen) and select show windows side by side for win7 or tile windows vertically for win XP
Nov 07, 2013 | Dell Latitude D800 Notebook
Hi, Dell D800 won't start up.
Can you F7 or F8 or whatever your system uses to get into the bios setup screen? If you can accesss that, you can install an operating system. If not, you have an issue. Put an operating system CD in to see if it is recognized for starters.
Apr 21, 2010 | Dell Latitude D800 Notebook
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Dell D800 Won't power up at all?
Bad news, this most likely indicates a problem in the charging circuit on the mainboard. To be sure, remove the battery and try again, if the same thing happens, then the problem is on the mainboard, if not, replace the battery. I have encountered this problem on an older Dell laptop before, removing the battery did not help and replacing the charger did not help. If the problem is on the mainboard, replacement is rarely practical. The cost of the board and the labor to replace it usually exceeds the cost of replacing the laptop.
Hopefully someone else has a better solution.
May 24, 2009 | Dell Latitude D800 Notebook
Vertical black bar across the screen
sounds like the screen settings are out, try changing the screen settings, not sure which button it is though i rarely play around with laptops
May 19, 2009 | Dell Latitude D800 Notebook
Cpu upgrade latitude d800
what do the Lock Lights indicate (Flashing , ON, ON perchance) it appears that the CPU is either not compatible or bad. Have you tried the original porcessor?
Jan 29, 2009 | Dell Latitude D800 Notebook
Tool, task bar and text miniaturized
right click on task bar... select properties... should be in there
Robert
Jan 21, 2009 | Dell Latitude D800 Notebook
My display does not show on the entire screen its just in the middle of my screen.Dell Latitude D800 PC Notebook pls assist.I re-installed the video driver it still does the same thing.
check the resolution settings, right click on the desktop if you are using vista then click on personalize and go to display settings and make sure that it is set to your desired settings.
If using XP then right click the desk top and go to properties then check your display settings from there.
I hope this helps
Nov 17, 2008 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
