Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
It Leaks. Leaks from openings in bottom of cannister one of which is square red button.
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Posted on Sep 30, 2010
The red pressure relief button on my GE Smartwater whole house water filter system is leaking what do i do to stop this
I had the same problem. The valve is not seating properly. I first took a plastic bag and placed it over the unit so it didn't spray all over, then, pushed the button several times to try to flush it. I then shut the water supply off (or move lever to bypass) and removed the cannister that holds the filter. I activated the red button several times until it looked like it seated well. Keep as much water in the cannister(sump) as you can and still have the filter seated properly. Screw it back on, and open the water supply slowly to fill the rest of the way. Don't push the red button again, but instead open a faucet in your house for around 5 minutes to let air circulate out. If the red button still leaks, you may have to try a few times. If it leaks just a little it may stop after a day or so. Once you get the red button to stop leaking, don't push it again! Just always use the open faucet method to work the air out. There will still be some air bubbles for awhile, but will work out within a day
Sep 13, 2012 | General Electric GE SmartWater Household...
I can't connect my controller to the wii console. Model number Rvl-001(USA). Model of nyko pistol accessory is Bn:090907 4632.My mom threw out the manual out by mistake.HELP!
  • Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote.
  • If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
  • If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
  • If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
  • Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
May 13, 2011 | Video Game Consoles & Games
How do i close my browser window
You can close your browser window by clicking on the red "x" in the top right hand side corner of your screen. The red "x" means "close". The "square" in the center next to the "x" means make "bigger". The - key next to the square in the upper righ hand side corner of your screen means "minimize". "Minimize" means bring the window to the bottom of the screen. It's like tucking it away or hiding it. If your window is full size and you click the minimize button, it will make the screen a smaller square in the center of your monitor. If you click it again, it hides the window at the bottom of your screen. You can see which windows re open by reading the labels at the bottom of your screen. To bring a screen back up to regular size when its minimized on the bottom - just click on it with your mouse.
Mar 03, 2011 | Mozilla Firefox
I can't get the bottom of the canister to open in order to empty the disrecarded material.
Remove the cannister from the vacuum. The bottom lid should release if you depress the red button at the top of the cannister, if this does not release the bottom lid, you will have to depress the red button while pulling the lid open. Either the release mechanism need repair or there is something jamming the bottom lid.
Let me know if you have any other questions. Thanks.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
I have a 03 dodge ram 1500 and got the codes p0440 and p0441. changed gas cap. where are all the parts located
P0441 - Evaporative Emission Control System Incorrect Purge Flow The "EVAP purge flow" faults are issues between the carbon cannister and the intake. The EVAP leak detection generally concerns the fuel tank to carbon cannister plumbing. A little background. The EVAP or evaporative emission system is a control system to keep vapors from evaporation in the fuel tank from getting into the atmosphere. The fuel tank is not vented, but rather the vapors are piped to the carbon cannister (usually located behind the pass. side front wheel) where the charcoal element absorbs the vapor. This is actually a vapor "storage" device. Under certain engine operating conditions, the ECU activates the Cannister Purge Valve (N80) which opens and allows the engine vacuum to **** the fuel vapors back out of the carbon cannister. This purges the vapor, allowing the cannister to absorb more vapor. This evap system has been on vehicles since the '70s. As part of the OBDII standard effective for 1996 cars and newer, it was mandated that leaks in the systems must be detected and reported as a fault which will set the Check Engine Light (CEL). To detect leaks, the system is pressurized by a pump so that leaks can be detected by a lack of appropriate pressure in the system. If there is a leak, such as a cracked vent hose, loose (or leaky) gas cap, poorly installed or defective O-rings on the fuel level senders on the fuel tank, etc. a code will be set. On the cannister to intake side, leaks are detected by deviations in the idle control system. If you have leaks in the lines from the carbon cannister to the intake, intake leaks, a defective purge valve, etc you will often get purge flow faults. My first recommendation is to closely inspect all the small vacuum lines connected to the intake manifold. The corrugated plastic lines are often the culprits, as well as the fabricate covered vacuum lines. Also consider replacing the gas cap.
Nov 09, 2009 | 2005 Dodge Ram 1500
Pulling up on button will not release bottom of cannister.
The gasket is sticking to the dump lid. While holding it over a waste receptacle, operate the release button and pull the waste gate at the same time. Rinse the canister and dry thoroughly. Apply a spray of silicone to the gasket surface, let it sit for a minute, and wipe off the excess with a paper towel. This should fix you up.
Best regards, --W/D--
Aug 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
P0441 code means what ?
Jul 06, 2009 | 2004 Dodge Neon
How do I open the dirt cannister on a dyson animal (purple) so I can empty the dirt out?
This is fairly easy. Click on the button at the top of the hand above the cannister. It's a purple button and the handle faces the front and says Dyson on it. This separate the cannister from the body.
Next, hold the now full cannister above a trash can and click on the red button which was below the purple button (but hidden when it was attached).
May 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a p0441 fault on my 2003 dodge neon. i changed the canister purge solenoid and the light went off for about a month and just came back on what could cause this?
Apr 22, 2009 | Dodge Neon Cars & Trucks
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
238 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
