Question about Acer Aspire 5315 Notebook
Key pads not responding
I'm failing to use keys on my lap top. What should i do? Help please
  • Nyimbs Mar 28, 2008
    The keys are not responding in any way.
  • 4 Answers
I think you may have locked the key pad when you type what happens ?
Posted on Nov 26, 2008
  • 242 Answers
Does the computer not respond to your keyboard in any way?
If warranty is still valid, contact the shop where you bought it, or contact acer..
Did something happen to the laptop? Fallen, water on it?
Posted on Mar 27, 2008
How do i lock and un lock my hp compaq 6220 lap top my cat keeps jumping on the key pad
There is no lock for the key pad, all you need is another USB key pad to deactivate the on board keypad.
The cheapest way is a "rolled newspaper", use that to bash that annoying cat!
Hope that helps you out!
Aug 08, 2011 | Computers & Internet
I have the Dell 1525. The screen is black with only the cursor appearing. Please advise
Check to see if you have the machine switched out to a stand alone monitor. This is a feature on many lap tops that lets you re-direct the signal out to a larger monitor, or if your monitor fails you can display the computer info on another screen. This feature is engaged by holding down the Fn key and tapping teither the F4, or F6 key on many lap tops. This feature can be toggled by both displaying at the same time or switched to the stand alone or the Lap top.
The other cause is that the machine has malfunctioned usually because of the CPU failure and there is nothing to boot the machine up.
Dec 30, 2010 | Dell Inspiron 1525 Notebook
Key pad not responding SHARP R-9H11
Without being able to put my meter on it. My first guess is that you have a bad board. I would say a high limit but it either works or don't work. It does not come and go. There is not a lot to a microwave. You have door switch's, Mag tub, fuse, fan, transformer, diodes, belt, high limit, pc board and a touch pad. This sounds like a pc board to me. Honestly, if it's not a fuse. Unless it's a high dollar built-in unit, they are not Worth fixing. You can buy a new one cheaper. This is why a lot of service company's don't work on them anymore.
Please rate this solution if helpful.
Aug 21, 2009 | LG LMVM1935 Convection/Microwave Oven
My laptop computer is okey except that the touch command for the cursor is not responding, if i use a mouse thru the usb port then its alright..why does the touch command for the cursor not responding?
Touch pads are not very reliable. I have seen a lot fail.
A computer repair person will need to replace it for you.
My advice is to stick with a USB mouse. Or if it is under warranty, take advantage of that warranty.
Best of luck.
Apr 26, 2009 | Acer Computers & Internet
Deactivate the touch pad
Try holding down FN key and F( key. This activated and de-activates the touch pad
Apr 25, 2009 | Toshiba Satellite A20 Satellite A25 Series...
Laptop not responding to my belkin
You would have to login to the router and see what the encryption level is, i.e. WEP or WPA, then you should see a obscure key checkbox, uncheck it to see the plaintext of the passphase, if the checkbox is unchecked when you log in then you should be able to see exactly what they are... Hope this helps!
--Joshua79
Apr 05, 2009 | Belkin (F5D7231-4) Wireless Router
Acer travelmate 2420
ok..then you will need to re install from a windows disk
Oct 16, 2008 | Acer TravelMate 2300 Notebook
Key pad
A couple of things. Make sure none of your keys are stuck. One key being stuck will disable the keyboard. Carefully depress each key individually and see if one of them is responding differently.
If you want to try, and its not overly difficult, remove the keyboard and unplug and re connect every connector and ribbon cable you can find. Often one of them becomes loose or has a so so connection that can cause it not to respond.
Let me know please.
Mar 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Acer Aspire 5315 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
