Question about Homelite Mighty Lite Lawn Trimmer
Tempermental throttle/engine easily floods and stalls out
I have new gas, new spark plug and everything is very clean. I have tried adjusting the carb screw, and tuning the wheel that spins from full choke to half choke to run.
I'm thinking this might just be a lemon.
Thanks in advance for any and all insight.
  • Homelite Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
Enging cranks but no start, has spark and gas
Your engine is flooded with fuel. Check your throttle body if it's a fuel injected engine. Clean it. Remove spark plug, let it dry or replace with new ones.Try flooring your acc pedal and start. If it starts, you need to get the carb serviced. For fuel injected, you need to service/ repair/replace your throttle body, fuel injectors, idle air control valves and EGR.
Jun 13, 2014 | 1994 Toyota Camry
Why does my craftsman 2-cycle model 316.791860. Gas trimmer die?
Those little carbs clog very easily and what you experience is a common symptom. Go to any bog box home store and in the mower area pick up a can of small engine carb cleaner.
Remove the carb, take it apart as far as you comfortably can and soak all pieces in a can/jar of CLEAN gasoline for 10 -15 mins. Agitate to get the gas moving.
Remove the carb, and drip clean then use the carb cleaner to blow out every port you can see. reassemble and install the carb, it should work fine.
Before storing for the winter drain all gas from the tank and start it allowing the machine to run till it stalls out due to no gas. You should be fine for next season that way.
Apr 27, 2014 | Craftsman Convertible 25cc. Gas Line...
Engine flooding with gas
try to clean carbs- had same happen to me. Cleaning them solved the problem
Sep 25, 2012 | 1993 kawasaki ZZR 600
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Starts ok when cold stalls when hot and wont re start, i have checked valve clearances
Do not twist the throttle when re-starting a hot engine. That bike floods easily. The power valve in the carb squirts gas into the cylinder with every twist of the throttle. A fresh spark plug will also help.
Feb 02, 2011 | 2008 KTM 250 EXC-F
I have a suzuki RM125. I was riding and it just stalled out. Engine quit and would not start again. I changed the spark plug and cleaned the carb. Drained the gas and refilled. Checked the shutoff switch...
If your confident of a good spark, then your issue is fuel delivery. Try raising the slide needle by going down one notch on the needle. Jets and needle seats should be cleaned in a good quality carburettor cleaning solvent. Jets should be replaced if suspect. Check condition of reeds. Is the airbox and filter in good condition. Check for leaks around inlet manifold. Goodluck, cheers!
Nov 13, 2010 | 2003 Suzuki RM 125
What is causing my 1986 jeep grand wagoneer engine to stall while driving? I cannot restart it but there is power. It will turn over but not start and there is gas in it. The jeep just went "poof" and died...
ok, its and old jeep, cranks but will not start.
carb fueled right? crank it wide open throttle to clean the flood
and block open the choke, if CARB has auto choke, if manual choke make sure its open. (push in knob... called choke)
fuses first. test them.
first check for spark in all cylinders.
if you have spark on all , then its flooded.
if no spark on one try a new spark plug and wire.
if all spark is dead , do the tuneup. now. all spark parts.
if spark is dead, check it at the coil, ? good there? or not.
that is a start.
if the carb is bad, we cant cover rebuilding it here.
stalls while driving has over 50 causes.
but bad spark or flooding tops list. (assumes engine is ok)
Oct 07, 2009 | 1985 Jeep Grand Wagoneer
VERY hard starting takes way to many kicks usually play out befo
There is a proper way to start the engine. Four controls are on your bike to assist in starting.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Give a strong kick through the full sweep of the kickstart lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from a backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Top rating for this answer? Thanks!
Jun 11, 2009 | 2003 Yamaha YZ 250 F
Saw starts, then stalls when you increase the throttle. Spark plug looks fairly clear. Ay ideas on where to look next?
Yes, you will need to disassemble carburetor and clean with carb. cleaner. If you need tips on how best to do this, just let me know. Or you may need a new carb. kit.
Jim
Jun 01, 2009 | McCulloch Garden
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
167 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
