Question about LG PCMICROSTORE Brand Rumor / Scoop / UX-260 Red Rubberize Textured Snap-On Case Cover with Removable Swivel Belt Clip
How do I remove easyedge from my cell phone? - LG PCMICROSTORE Brand Rumor / Scoop / UX-260 Red Rubberize Textured Snap-On Case Cover with Removable Swivel Belt Clip
How to remove lcd screen on kyrocera hydro
  • Remove the battery cover from the back side of the cell phone. Remove the battery from its compartment and set it aside.
  • Use the screwdriver to remove the Phillips-head screws from the back panel of the cell phone. You may also need to remove the antenna from its retaining slot and remove it from the cell phone if you can
  • Separate the back panel of the cell phone from the rest of the cell phone's body. Place the cell phone face up and then remove the cell phone's faceplate from the rest of the cell phone. This should leave the LCD screen, keypad and circuit board completely exposed.
  • Tilt the LCD screen downward and then disconnect the LCD screen's ribbon cable from the LCD screen and set the screen aside.
  • Repeat this procedure in reverse to replace the LCD screen and reassemble the cell phone.
Mar 17, 2014 | Boost Mobile Kyocera Hydro Smartphone
My phone have virus how it will be remove
to remove the virus you can search in these websites
www.nospysoftware.com/spyware.../mobile-phone-virus.php
filetonic.com/.../how-to-remove-a-virus-from-a-cell-phone
www.ehow.com > ... > Cell Phones & Accessories > Cell Phones
www.maybenow.com/Virus-in-a-cell-phone,-how-to-remove-it-q24196448
THANK YOU
Dec 17, 2010 | Nokia 3230 Cellular Phone
Iwant to know how to install lcd screen
  • Place your cell phone face-down, remove the back cover, remove the battery from its compartment and set it aside.
  • 2
    Remove the Phillips-head screws securing the back panel of the phone. This portion of disassembly varies from phone to phone. Some cell phones require that you pry off the back panel with a thin plastic object such as a guitar pick or credit card. Remove the back panel and set it aside.
  • 3
    Remove the circuit board. This part of the disassembly process varies from cell phone to cell phone. Most cell phones require that you remove the screws securing the circuit board in place. After the screws are removed, you may be able to completely remove the circuit board, but many phone require that you disconnect one or several ribbon cables connecting the circuit board to the keypad, LCD screen and camera. Lift the circuit board out of the phone and set it aside.
  • 4
    Remove the now-exposed LCD screen. You may need to remove a few small Phillips-head screws. Lift the LCD screen out of the cell phone casing and set it aside.
  • 5
    Follow this procedure in reverse to install the new LCD screen into your cell phone and re-assemble the cell phone casing.
  • Oct 09, 2010 | Cell Phones
    Water damage how can i try an fix it? on a samsung gravity 2
    Follow these procedure to save or revive your phone, remove Cell Phone from Water: Time is of the essence when it comes to saving a fixing a submerged cell phone, as soon as you see your phone in water, remove it quickly! Every second matters do this step quick.
    Saving the Battery: In order to save the battery on your cell phone after it's been wet, quickly take the battery out of the phone as soon as you take it out of the water. Buy doing this you will ensure that minimal damage is done to your battery.
    Drying the Phone Out: Quickly shake your cell phone to get all of the water out and reach for the paper towels. Press down on your cell phone to make sure all of the excess water has come out. If you have accessories such as cell phone covers, take them off promptly otherwise water will still be stuck in your phone.
    Saving your Info: If your cell phone takes a SIM card, quickly remove it before the phone dries. While you may still loose some of your information, you won't lose it all if you take the SIM card out of your cell phone in time
    .Removing Excess Moisture: To remove the unseen moisture in your cell phone you will need to cover it with either Desiccant gel packs or rice. Desiccant gel packs can sometimes be found when purchasing brand new shoes or clothes. Make sure your cell phone is completely covered with either one of these for up to 3 hours.
    Vacuuming: Take your vacuum hose and place it up to 4 inches away from your cell phone with it on. While this won't remove all of the water, it will certainly eliminate the big spots of water damage.
    Turing the Phone On: After allowing your cell phone to sit a day or two with the power off, turn it on to see if it works. More than likely if you followed these steps as soon as your phone was submerged, it will cut on. If not, you will have to purchase a new cell phone because the one you have can't be saved.
    Take care.
    Jul 18, 2010 | Samsung Gravity SGH-T459 Cell Phone
    How to delete ringtones off the samsung SCH-u340. From US Cellular.
    1. While in standby mode, press the OK button for Menu
    2. Select Multimedia / easyedge [This depends on your phone] (4)
    3. Select Gallery (2)
    4. Select Melody Gallery (2)
    5. Select Downloaded (2)
    6. Press the left key for 'Options'
    7. Select Erase [or Erase All]
    8. Highlight Yes, using the navigation keys
    9. Press the OK button
    Jan 15, 2010 | Samsung SCH-u340 Cellular Phone
    My phone freezes when i push the button to go to easy edge.
    your phone cannot run it, sorry, it does not meet the tech specs.
    Jun 10, 2009 | Motorola Mobility RAZR V3
    I can't find my saved sounds.
    go into the menu and go to easyedge and then go into the gallery then melody gallery and then into downloaded and they should be in there
    Apr 27, 2009 | Samsung SCH-u340 Cellular Phone
    Unlock DRM on LG Scoop
    I ******* hate the alltel scoop i just got one and i used to get my other ringtones from phonezoo.com but now the **** doesnt work on it...what a peice of ****.
    sorry that i couldnt help!
    Mar 28, 2008 | Cameras
    Speakerphone
    with the phone open press and hold the top left button on the side of the phone (up beside the screen) untill the speakerphone turns off.(about 1/2 sec.)
    press the center round button to get a list of all of your phone options (menu, tools, etc...)
    Dec 29, 2007 | Motorola Mobility RAZR V3i Cellular Phone
    LG PCMICROSTORE Brand  Rumor / Scoop / UX-260 Red Rubberize Textured Snap-On Case Cover with Removable Swivel Belt Clip Logo
    981 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
