Question about Olympus Stylus 400 Digital Camera
The lens doesn't open - Olympus Stylus 400 Digital Camera
How do I fix shutter problem on my Fujifilm Instax 210??? (Lens shutter doesn’t open )
The lens shutter to which you refer is actually the lens cover - the shutter itself is located within the camera, and controls the exposure.
Nov 20, 2017 | FUJIFILM Photography
What does fEe mean on Nikon 35 mm camera
This means that the lens doesn't have its aperture ring set to its smallest opening.
Turn the aperture ring to its smallest opening (largest f/fnumber) and lock it if the lens has an aperture ring lock. You control the aperture from the body, the same way as with a lens without an aperture ring.
Apr 01, 2012 | Nikon Photography
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Won't read disc
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.....
Aug 10, 2011 | Sony MHC-EC68 Audio Shelf System
I have a sony xav-622 in a new rv camper. Everything works except the connection to the sony tv on the dvd only plays in black and white. This is connected with a yellow cable with no place to put s...
try cd/dvd cleaning lens kit of your XAV-A1. if still it doesn't work, try opening you XAV-A1 and clean it with a cotton buds with a cleaning solution from the cleaning lens kit. if still it doesn't work, have it change a new lens from a certified technician.
Apr 25, 2011 | Sony XAV-60 Car Video Player
Foldable lens cover doesn' t open and closed fully... Thanks.
It's usually merely a grain of sand or dust jamming it. But it's also usually easy to fix. This link outlines repair techniques for a stuck automatic lens cover. Recommend trying the less "risky" ones first before considering the end of the lens.
Dec 27, 2010 | Canon PowerShot A610 Digital Camera
Camera doesn’t start
The only solution that I found is to take off the battery from camera. After I reconnect the battery, the camera starts without any problem (lens are moving, LCD is on, AF is also on). The battery status is full.
Sep 12, 2005 | Samsung Digimax V5 Digital Camera
Olympus Stylus 400 Digital Camera Logo
18 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
