Question about HP Deskjet F4100 All-In-One InkJet Printer
I have hp f 4100 inkjet printer its cartridge is not printing good it looks to me that its head used to dried up while printing as it starts printing the page but around about one third page is printed every time and then it dosent print anything when i clean the head of the cartridge same happens again please help me PARUL JAIN PARULJAIN1294@GMAIL.COM
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
My hp dj9000s printer is switched off since 6 month, now I switch on it shown error message for Lc, Lm ink cartridge. (cartridge is ok I replace with new one but error is same)
If an inkjet printer has not been used for some time and several print head deep cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 25, 2011 | HP DesignJet 9000 InkJet Printer
Something keeps installing copies of my printer in the control panel. I have three HP 4100 deskjet prinyers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 24, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
When i try to print a photo i get white stripes across the photo. I bought a new ink cartridge but it didn't help.
White stripes across a print-out usually indicate clogged printer heads: look at your user manual on the cleaning procedures.
You can try cleaning BOTH the Black and Color cartridges heads by gentling cleaning and wiping the heads with clean moist tissue paper/kitchen paper. Also clean and dry the contacts (eg. copper looking printed circuit).
For bad and very dirty print heads, I also use a warm shallow dish of water and wash the head only and then dry off with clean tissue paper.
After re-inserting the cartridge, I suggest that you do a cleaning cycle and alignment and do a test print to ensure that the printing is back to normal.
Hope it helps: let me know how you go.
Dec 13, 2010 | HP PSC 1510 All-In-One InkJet Printer
I bought an Inkjet 2800 on ebay which had almost never been used ,it still had the original ink cartridges in which were full. The printer was idle for 3 years and now I can`t get a decent print, All the...
Inkjet printers do not like being unused, especially for years. The print head nozzles get clogged with dried ink when they are unused and even when you insert new ink cartridges the inks won't flow through the nozzles properly. The solution is to replace the print head.
Oct 28, 2010 | HP Business InkJet 2800 Printer
My HP Deskjet D4260 printer has been unused for 2 years. I have been told it would be useless to replace dried cartridges, because the inkjets themselves are probably clogged, and therefore the printer is...
That is absolutely not true. The printer you have uses integrated print head cartridges. This means every time you replace the ink cartridges you are replacing the print heads. Throw out the dried up ink cartridges and buy new ones. Your printer takes the HP 74 black and HP 75 color cartridges. There are XL versions of these cartridges that hold more ink and are a better value.
Dec 19, 2009 | HP Deskjet D4260 Printer
We have a photosmart 7760 but whenever we want to switch to the photo cartridge (58)and print a few photos and then switch back (56) for regular printing, by the next time we go to print photograghs the 58...
When you take the cartridge out, wipe the head (the gold area on the bottom) with a slightly damp tissue and put a piece of scotch tape on the head to seal it from air. It should maintain the cartridge in good condition until the next time you use it.
You can also look for some special inkjet head cleaning solution, which can be used to revive a dried-out printhead.
Dec 11, 2009 | HP PhotoSmart C4180 All-in-One Color...
I have a HP Deskjet 882C printer and for the past month we are having problems printing text (B&W). We have removed the black ink cartridge and it still has a lot of ink in the cartridge. When we put a...
To clean the HP Inkjet print cartridges from the HP Toolbox, using a Windows operating system, perform these steps:
  1. Double-click the HP Toolbox icon on the computer screen.
  2. Click the Printer Services tab.
  3. Click Clean the print cartridges and follow the directions on the screen.
If the print quality improves after completing this sequence once, but the quality is still not quite good enough, repeat procedure. Start at Step 1, or click the Clean Again button on the final cleaning window. If this process does not improve the print quality, the HP Inkjet print cartridges might be low on ink. See the document that is provided with the black HP Inkjet print cartridge for instructions about how to use the ink level sensor to determine if the cartridge is low on ink. Replace the HP Inkjet print cartridges, if appropriate.
Jun 25, 2009 | HP DeskJet 882c InkJet Printer
Print quality reduced.
You probly have a cloged cartridge. Most of HP's cartridges are water based ink. Take the cartridge that is not printing good, color or b/w, set the copper colored end, which is the print head on a dry paper towel. You should be able to see all colors as a solid line, or the black will show 2 solid black lines. The one that is not correct, take a paper towel and get it damp, and set the print head on the damp towel, be sure to fold the towel or it will stain the table you set it on. and let it set for a few minutes. Try the dry towel again. You may have to do this several times..You also should have software to prime your cartridages. After cleaning, try to prime the cartridge.
Feb 27, 2009 | HP DeskJet 5150 InkJet Printer
I have a hp psc 1210 all in one,it is playing up with print outs, is it possible for me to replace the print head on this model Rick
HP printers use cartridges that ARE the print head. On occasion, the cartridge could be defective...especially if they are the remanufactured type. Try replacing your cartridge with a new HP cartridge.
May 29, 2008 | HP Office Equipment & Supplies
HP Deskjet F4100 All-In-One InkJet Printer Logo
306 people viewed this question
Seeker5211
Seeker5211
