Question about Amana ACS3350AS Gas Kitchen Range
Incorrect temperature in oven
My oven has had the ignitor and temp sensor replaced very recently (2 days to be exact) and it is not heating to the temperature that i am setting it to. for example, if i set it to 350 degrees, it heats up to 180 degrees. if i set the temperature to 550 degrees, it heats up to 300 degrees. i'm at my wits end and would like to know what could the issue be?
  • Anonymous Mar 24, 2014
    I set the bake temperature and press "Start" but the oven never heats up.
Refer to the manual about setting the temperature. When the unit ships from teh factory they set the temp. you may need to recalibrate it.
Posted on Sep 03, 2008
The computer needed replacement. i just purchased another range instead.
Posted on Mar 28, 2008
6ya staff
SOURCE:
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Westinghouse 662 Oven temp is wrong, by about 100 degree's.
would check to make sure both your broil and bake ignitors are working. On some, but not all, both come on to preheat, and then the broil shuts off. Another, and more likely culprit would be the temperature sensor located in the oven itself. Its the silverish metal rod protruding from the back wall inside the oven. It could be bad and not converting heat/elsectrical signal properly causing the main control to regulate the temperature incorrectly.If the sensor you are talking about is the oven temperature sensor than its just as easy, since you are behind the machine already, to take off the back panal, unplug the sensor and measure resistance there. Either way the resistance should read around 1099-1100 ohms.even a small margine off can cause a major temperature difference.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Frigidaire Ovens
Kenmore Oven (model 3627361190) underheats when baking.
Double check the sensor. It should ohm at 1150. Look for a frayed wire on the sensor.
Oct 12, 2009 | Kenmore Ovens
Whirlpool accubake oven (elec) E-2 F-3 fan running oven wont't heat all other functions normal
Hi, your oven will not heat if the temp sensor is faulty or damaged. this code represents a non-responsive oven temp sensor.
Replace Oven temperature sensor (RTD)
Aug 15, 2009 | Ovens
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven shows temperautre but does not get very hot
most likley you have a burned out elements, the tempature is probably just the temp you are selcting, if I am incorrect in the temp, ie, it does show the temp as oven heats, then the most likley problem is the tempature sensor is faulty or wiring to the sensor is faulty.
Apr 10, 2009 | Ovens
Oven Temperature Probe
It could be your ignitor, if weak it might not be good enough to draw ampage.I would suggest to change both ignitor and temp probe to be in a safer side. part number for ignitor is 12872 $56.0+, Part # for your oven temp. sensor 833085, it should not be more than $28. other part from www.repairclinic.com.
Jul 25, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven won't heat up to set temperature
IF THIS IS A GAS RANGE, AND IS USED ALOT, 4YEARS IS ABOUT THE LIFE EXPECTANCY OF THE IGNITOR FOR THE OVEN. IF THE IGNITOR IS WEAK, IT MAY NOT OPEN THE SAFETY VALVE. WITH A FLAT IGNITOR, IT REQUIRES 3.3AMPS TO OPEN THE VALVE. IF IT IS A ROUND IGNITOR, IT REQUIRES 2.8 AMPS TO OPEN THE OVEN IGNITOR.
IF THIS IS AN ELECTRIC OVEN WITH AN ELECTRONIC CONTROL, I WOULD SUSPECT THE OVEN SENSOR AS THE DEFECTIVE PART. AT ROOM TEMP, IT SHOULD READ ABOUT 1084 OHMS OF RESISTANCE.
IF IT IS A MECHANICAL CONTROL(WITH A KNOB) IT MAY BE ADJUSTABLE BY REMOVING THE KNOB AND INSERTING A THIN SCREWDRIVER UP THE SHAFT OF THE CONTROL AND TURNING A SCREW IN THE SHAFT TO CALIBRATE THE TEMP.
Apr 04, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Temperature is Unstable
erratic temp in oven can also be a bad oven ignitor, usually to low of a temp and not able to stay at temp, too long to preheat.replace the bake ignitor
Mar 11, 2008 | Hotpoint RGB745 Gas Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
288 people viewed this question
Top Amana Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
