Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Put new master cool pads on smells like fish - Mastercool 67471 Evaporative Cooler Air Conditioner
What do I use to clean fish smell out of freezer
Baking soda will eventually work but to remove the smell now...diluted bleach and warm water....1/4 cup to 2=3 quarts of water will do the trick.
Jan 11, 2015 | Refrigerators
How do i get rid of fish smells out of the carpet in my car?
You may have to have the carpet cleaned as fish smell is hard to remove . You can hire a wet and dry vacuum cleaner from Woolworths , It should do the job.
Oct 20, 2014 | Cars & Trucks
Refrigerator smells like fish
Put a couple of boxes of baking soda in the fridge to absorb the smell.
Apr 18, 2017 | Thermador Refrigerators
Burning plastic smell from under hood
You will need to check where the liquid is coming from, It may be anything from Air Con, Fuel, Transmission Fluid etc..
The fact you smell burning plastic could be 3 things..
1, Brake pads could smell and burn down if they are on too tight (Had this problem with a trailer). Hence when you apply the brakes it could be squirting brake fluid out due to too much pressure.
- Check brake fluid
2, If the smell and liquid is inside the car (front pass side) it could be the air ducts. Under the dashboard you have air ducts etc for the fans and in car cooling (brother had issue with this)
3, Whatever the fluid is, it could possibly drip onto something hot, unusual for liquid to smell like plastic though, Auto transmission oil smells like fish.
Best bet would be the brakes. Next time you smell it just smell in the wheel mag and see if you can smell it, check the engine fluids often and dont use A/C (Air Con) as that does drip fluid (normal). If it is the brakes smelling you will need to have the lines bled out, tyre places may be able to do this, and possibly new brake pads
Good luck
Oct 20, 2012 | 2007 Suzuki XL-7
Put new brake pads on, now brakes were smoking. Sticking caliper?
They are rather easy to replace, disconnect the brake hose, and remove the caliper as you did replacing the pads. You'll need to then bleed the caliper until clear fluid, with no air bubbles come from the bleeder screw. Check that you don't have a collapsed brake hose, not letting the fluid return to the master cylinder.
May 24, 2010 | 1992 GMC Jimmy
Stink-ola!
I would call out Maytag as it looks as if an insulator on the motor is burning out.
Or a connector is overheating
Get it checked in case you have a fire
Jul 30, 2009 | Electrolux Refrigerators
Water pump size and over saturated pads
Louis, The cooling does not come from the volume of water running over the pads. It cools by cooling the air passing through the wet pads. So, Yours is an impeccably logical argument that leads to a false conclusion. Bigger is not better in this caThe fishy smell is from the matting (pads) when kept saturated, Molds and algae will form if there is too much water also.. Best you get the original size pump Good luck and stay cool - Ned
Jul 25, 2009 | Mastercool 67680 Evaporative Cooler Air...
When the load is in mid-wash it smells like a fish cannery! The whols house will smell like fish. The dishes will all smell like fish. I put lemon and vinegar down the disposal and it worked for a few...
You might want to try adding a jar of "Tang" orange drink to the dishwasher and running it through a wash cycle.
Empty the washer, remove the racks.
Fill the soap dispenser with Tang and put the rest in the bottom of the washer.
Set the washer to run a normal wash cycle and when it is finished it will have cleaned out your dishwasher.
Now depending on how much debris is in the washer, you may have to do it twice.
Worked for me. Good luck.
Regards,
Jul 21, 2009 | Dishwashers
New Mastercool pads smell bad
The cellulose pads in a mastercool are glued together and usually the adhesive is what you smell. It may take a while for it to go away. Strange as it may seem, as the pads get more mineralization and you use it more the smell will go away. Do not use a cooler for your whole house without plenty of exhaust through a window or an updux. Coolers work best when there is plenty of freely moving air.
May 14, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
273 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
