There might be a problem with the battery , just show a light thunder and thats it . Do not charge it and the phone does not start his applications . Looks completly dead only with the thunder on the screen.
3 logical possibilities comes to mind: 1) Battery is faulty. 2) Charger is bad, not connected to an active wall outlet or not making good connection with the tablet. 3) There is a software issue, possibly with the application that shows the battery status.
you have a bad battery. the best solution is to replace the battery.
to extend the battery life you can close background applications and turn of the screen, in this case that most lightly wont help a lit though.
Make sure always bluetooth and camera shutter turned off. set brightness(senser ) to minimum, Try to charge battery after full empty of battery, Only charge 2 and half hours maximum, Buy a genuine battery(original). Make sure all application closed (Minimisation of applications cause charge removal),(Press and hold menu key show if threre is any applications works on background), Try to format phone by press *#7370# Install a good antivirus(netquin)
Hi,when a phone does not come on, it is either the battery of the phone is dead, might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored back the phone memory. will need to be flashed.
Hi, when a phone won't turn on or blinks red light, it 's either the battery cell if too weak to power up the phone all application you downloaded on the phone has VIRUS and has affected the phone memory.
First Charge the battery forlonger hours before using another battery to confirm if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life. You can use the link below to know about how to flash the phone.
Did you download from the internet?.If yes, that means it has been affected by virus by installing or downloading an application.
You can also check the battery too, cause the cell of the battery might be weak and needs to be charged.charge the battery for a long time and see if it will come up, or get a spare battery to check.
with the red lcd light blinking it means there is a software issue try syncing it with your blackberry desktop manager the application loader if that doesnt work u will need to contact you service provider for replacement options
I suggest you to check the battery status.
If the battery is not charged completely handheld does not turn on.
If the battery is fully charged and still the phone is unable to turn on, then check with the other battery.
Inspite of that you are facing the same problem, visit the outlet from where you have purchased the handheld to service.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
