Question about Homelite Expand-It Hedge Trimmer Attachment
My ryobi expand it starts but as soon as i put it on run it stalls why???
  • 64 Answers
Not getting enough fuel through the main jet. clean the carburetor good and check the fuel filter to see if it has restriction.
Posted on May 08, 2010
My Ryobi ry3002a weed trimmer won't idle. It shuts off as-soon-as I move the lever to run position. I disassemble and clean the carburetor but no luck. Any suggestion?
Run at 1/2 choke rev the engine & count to 10 showly. The engine should now be warm enough. If it still stalls, turn up the low idle screw.
Aug 24, 2015 | Ryobi Garden
Is there a manual for the ryobi expand-it 26 cc power head?
hi there
unfortunatly ryobi have not released the repair manuals for the new strain of ryobi only the plt and pbc models
but i am in the middle of writing repair manuals for them
keep an eye on ebay very soon
watch this space
if you need to know anything else
email me:
sales@streetfighter-customs.co.uk
regards
neil
Jan 02, 2013 | Ryobi Expand-It 2 Cycle 26cc Trimmer Power...
Have ryobi 700 720 trimmer difficult to start when it starts it only runs 5-6 mins thenstops
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, !!
Oct 19, 2011 | Ryobi 15" Electric Factory Reconditioned...
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel lines!
Sounds like you need to adjust the carb. Remove the caps from the carb. Turn both screws clockwise until all the way seated. Start the trimmer and while running begin to back out the screws slowly until the trimmer is running strong but is smooth. Once you have the carb adjusted you can put the caps back on or you can discard.
Oct 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
You should have 2 small adjuster screws next to each other on top of the carb.Try adjusting each of them a little with a thin screwdriver as the engine is running.Put strimmer on the ground first and adjust screws while you are revving engine until it runs correctly.Trial and error and very small adjustments can make quite a difference.Hope this helps.
Jun 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite Expand-It Hedge Trimmer Attachment Logo
609 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
