Question about Panasonic AG-DS555 S-VHS VCR
Rolling static pattern
When capturing some old S-VHS material, I thought that the tapes had deteriorated badly as there were many drop-outs! However, I don't think that the tape is the problem. When paused, a pattern of "static" (a band of flashing white specks) slowly rolls from bottom to top of frame. I tried adjusting tracking & cleaning the heads but problem is still there.
Doug Knutson
Windswept Productions
  • Windswept Mar 27, 2008
    Me again.
    A new ripple in this - the band of "rolling static" only occurs when the deck is controlled remotely (RS-422)!?? I am controlling it from Final Cut Pro via Keyspan USB to RS-422 converter.
    Will keep working on this & will post any results - but would appreciate any insights!
Solved! (I hope??).
The cable from the Keyspan to the AG-DS555 deck had an extension cable - when this was removed, the rolling specks disappeared!!! I tested the same set-up on a JVC DV deck and didn't see any problem?? But I suppose that S-VHS is much older technology - I hope that this was it!
Guess the moral of the story is - check every cable!
Posted on Mar 28, 2008
SOURCE:
No Auto Stop on EZ Grab when VHS is done playing
hi, as long as you don't have a professional VHS player/recorder with a serial control, and a dedicaded software to control it, it is impossible for your soft to know that VHS as finished, you don't have the problem with a firewire input, as the control passes by the FW cable in the two directions, but you can solve that (easy way) by setting up the capture time to approach the real timing !
for the MP4 format, the easy graber doesn't capture in this format without the use of the CPU, because it doesn't have hardware encoding, so that's why you can't reach good quality by capturing directly on MP4, you would need a card like hauppage game capture to have full MP4 (H264) hardware encoding with really good quality, and without any CPU use !
Mar 13, 2014 | Diamond Multimedia ( VC500) Video Capture
I have a VHS tape that has an hour worth of recorded material on it, but when I play it, it plays the first 11 minutes, then it goes to static and the counter stops counting. I can fast forward but when I...
You may think the tape has an hour of material on it, but the machine thinks otherwise. Either it didn't actually get recorded past the 11 minute point, or something erased the tape past that point. There's nothing to play after that time, so you're seeing the snowy screen. On most VCRs, the tape counter only works when a valid video signal is detected, which is why it's not advancing as the tape plays. There's nothing you can do to recover whatever was on the tape, so I hope it wasn't anything important.
Aug 11, 2011 | TDK E-HG 120 VHS Tape
HI There I have an old camcorder the Model is a JVC GR-DVL 150E i have some very old footage on the camcorder tapes, i never ever got around to transfering the footage on to vhs video tapes! but now i...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 27, 2011 | Cameras
Hi There! I have an old camcorder, model is a JVC GR-DVL150E . I would like to know if its possible to transfer my footage from the tapes on to my PC and save it to discs! if so how do i do this and what...
Thanks
Jun 26, 2011 | JVC Video Cameras
How do i go about transfering vhs-c video from an
You have several options. But important one to understand is the limitations of a PIII computer like Armada e500. You may not have enough grunt to convert stuff, even after buying the necessary video capture devices which work on USB.
Also I am assuming you either have the jvc camcorder still available or atleast have a VHS-C to VHS adapter to play the tapes on a standard VHS tape player.
Unless you are having a lot tapes and need editing while converting, your better bet might be to go to one of the shops that convert these tapes on to DVD or a suitable flash drive which might work out cheaper and quicker.
The last time I did this thing (quality of my VHS-C tapes was bad) I bought a Samsung combined VHS Video / DVD recorder and used the dubbing feature to burn DVDs. Cost me about $150 a year ago. I was able to do some editing on the way as I was connected to the TV screen as well. Saved me the hassles of dealling with the PC type video capture devices and software.
Dec 25, 2009 | JVC S-VHS Tapes (ST120SVDU2) S-VHS Tape
Video8 tapes upload to computer
You need a capture card or firewire output in your camera (This is faster) these capture card bring a software also for editing. If firewire, there is Premier Pro for PC or Final Cut for MAc. Make sure you have the right output connector on your Camera.
Nov 27, 2008 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Vhs tapes
All you will need is a capture card. You can pick these up at a circuit city or Best buy. Then they will connect via the RCA cables. out from the VCR into the capture card. You can also get USB capture cards for ease of installation.
Thanks,
Lee
Jun 15, 2008 | Televison & Video
Static cling with 3 quarter inch tape
Ngotsa, Static is NOT the reason for your fuzzy audio. Old tapes tend to deteriorate because of 1.) the way they were stored (damp, humid, and extremes in temperature), or in, or near an electric field (motor, refrigerator, TV) 2.) the lubrication (which is on all tapes) has evaporated - making good tape to head contact impossible) or 3.) the oxide (the actually tape coating) had deteriorated. As far as the Black Backing, the black backing on your newer tapes IS there to prevent static, but mainly for static build-uop during high speed rewind; if it wasn''t there, you'd actually see sparks, and you'd ocassional zaps in the sound (not overall fuzziness).
Feb 06, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Panasonic AG-DS555 S-VHS VCR Logo
151 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
