Question about Philips SPC700NC Webcam
My phillips SPC700NC web cam is no longer recognized on my computer (Windows XP). Also, I no longer have the disc to install the software. What do I do?!
  • 198 Answers
Try the manf website for a driver download---if not, try driverguide.com---1000's of downloads free
Posted on May 09, 2010
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Laptop wont install my disc for phillips SPC210NC WEBCAM
Try using an updated copy of the software direct from Phillips HERE.
Jun 15, 2009 | Philips SPC700NC Webcam
I lost my installation disc for my Phillips DMVC300k web cam. For some reason my computer does not recognize my webcam and I need to re install it.
Go to this website:
http://www.support.philips.com/support/html/index_us_en.html
Afterward enter this into the search field: DMVC300k
Now press ENTER (on your keyboard) or click, "Search." Afterward two results should be returned, click on the one that matches your Web-cam's specifications. Afterward click the link labeled, "Software and Drivers" located on the left. Afterward download drivers for the web-cam and follow the instructions to install your web-cam.
Let me know how it turns out, and if you need some more support.
Mar 09, 2009 | Philips Computers & Internet
Phillips spc 700 NC webcam
hi,i think the installation software is corrupt.
you can download the software from this link
http://www.nodevice.com/driver/company/Philips/PC_Camera.html
Dec 16, 2007 | Philips SPC700NC Webcam
Philips SPC700NC Webcam Logo
80 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
