20 to 24 minutes?
A) Plenty of time for the Processor (CPU) to overheat, and turn off. (BIOS turns it off)
1) Heatsink fins clogged with 'Gunk'?
(Dirt, dust, lint, hair, old socks {No}, banana peels {No)
2) Processor fan, and computer case fans dirty?
3) PROPERLY replace the Thermal Paste.
Thermal Paste looses it's thermal conductivity properties over time, so don't think you can just stir it around a little bit, and everything will be fine. Properly clean, and use fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274B) Check the Electrolytic Capacitors on the motherboard.
(IF used.
ECS motherboard?
Since they are budget motherboards, there is a good chance Radial Aluminum Electrolytic Capacitors are used, and very few, if none at all; Solid Polymer Capacitors)
http://capacitorlab.com/visible-failures/index.htmBelieve the problem to be more heat (Overheat) related, though.
[FOLLOW Anti-Static Procedures! ]
For additional questions please post in a Comment.
Also post the model number of the Elitegroup Computer System motherboard.
Post back in a Comment/Reply
Regards,
joecoolvette
Hey there nimjong, the thermal paste is there to aid in heat transfer from the cpu to the heat sink, or heat sink and fan. It is not recommended to run a computer without the heatsink and/or fan attached. This could result in the processor core burning out. What combination are you using, and are the fans, if any, working? Also have you run the cpu without the heatsink attached. Please provide as many details as you can.
