Question about Grilling
Can a natural gas Charm Glow grill be converted to
We want to convert a Charm Glow grill which is connected to a gas line to a propane gas tank. Can this be done?
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 | Grilling
Convert from Gas to Propane - I had this grill converted by a plumber from propane to gas (I believe he changed the nozzles and added a gas line instead of the propane line). I've had to move the...
The "nozzles", as you called them are actually the burner orifice. If you remove the burners and look back into the control panel, you should see the orifices that the plumber installed. They unscrew with a nut driver to be removed. Do this one at a time, installing the LP Gas Orifice immediately after removing the Natural Gas one. Be careful not to mix them up and reinstall the Natural Gas ones.
You will also need a LP Gas Regulator/Hose Assembly to connect to the grill tank, that you will be using. You can pick one up at any hardware store or home improvement center that sell grills & accessories. It runs about $30.00.
Below is a link to the Owner's Manual. But, I'm not sure it will be of help in changing the orifices. But, it's good to have for future reference. You can download and print it.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/80003061.pdf
I hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 08, 2011 | Char-Broil 463254405 All-in-One Grill /...
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Need to convert our Q300 propane grill to natural gas. Do you sell conversion kits?
Unfortunately, Weber grills are not convertible from one gas type to another. There are no conversion kits available for your model or any Weber model gas grill.
To confirm this, go to the following link and on page 2 under Warnings, last paragraph, left hand column, you can confirm this, if you like.
http://help.weber.com/manuals/pdf_files_2011/Gas/Weber%20Q/Q300320_OwnersGuide_41060_021011.pdf
The only advantage to converting it to Natural Gas is not having to refill the grill tank. The downside, is that you will loose the heating capability that Propane has. It burns cleaner and hotter than Natural gas, in an outdoor environment.
Hope this helped you. Happy Grilling!!
Jul 13, 2011 | Weber Q300 Grill
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
I want to convert a Grill Master naturaal gas
The orifices have to be changed.Should be able to get right ones from manufacturer.
May 22, 2010 | Grilling
We received a natural gas connection bbq and don't have access to gas...is it possible to convert to propane tank connector.
no all components of grill need to be converted to propane. cheaper to buy new grill. Call Manufacture and see if they sell conversion kit. Most companies don't do to liability matters,
Mar 28, 2010 | BBQ Guys BBQ400C/G42 Grill
Natural gas grill needed to convert to propane
You would need to do the old crank down and flip routine. Crank down all spuds, open shutters all the way and flip the regulator nut to the LP position.
I found an interesting video on youtube which features gas stove conversion. Gas range conversion is basically the same.
Mar 07, 2010 | Weber Genesis Silver B Grill
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Grilling Logo
46 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
