PC problems my monitor is saying there is no video input and i have my computer hooked up to a workplace network and a laptop which i can remove from it's docking station to use elsewhere after having retrieved a network file that I might need. I just put my laptop back on its docking station and now there is apparently no video input and nothing works and i can't turn on the computer or the lap top separately and i can't turn anything on when the lap top is on the docking
What is mean by ntldr missing how can i slove the problem with reinstall os.
thanks & regards
Posted on Mar 27, 2008
Asus as cm1630 cp ws 830/18g has no video
Check to be sure the monitor cable is seated properly on the computer and the monitor. If still no input, try a different monitor (borrow one from a friend, family, or another computer). If another monitor works, your monitor was bad.
Jan 28, 2014 | ASUS Computers & Internet
700 g goes blank says input: analog
Hook a spare monitor to the pc computer, if picture okay! problem lies in the 700 g but if both show the same, it is the video graphics card in the computer that is defective. It would be a good idea to change the video cord from the computer to the monitor to rule it out.
Apr 16, 2012 | Computers & Internet
My monitor, keeps saying it is going to sleep. VGA says no input signal, as well as DVI. And I know nothing about computers
If there is no output on the screen, check all you cables and connections and ensure they are snug and secure. If there is still a problem, it is possible your video card is to blame. As a diagnostic step, try hooking the monitor up to a different computer. Or hooking up another monitor to your computer. This will help eliminate bad cables and connections. If a different computer works on your monitor, then you most likely have a bad video card. If you monitor still will not work on any computer, then you most likely have a bad monitor.
Feb 28, 2011 | HP w1907 LCD Monitor
I just purchased a acer h203h and when I hooked it to my computer it says no signa and light turns red.
Please check the video input selected, press Menu botton, the monitor will show you among other information the input selected, if indicates VGA, you must have connected the corresponding cable between your PC and monitor, if it indicates DVI and your computer doesn't have DVI port press the Input botton to select VGA.
Feb 22, 2011 | Computers & Internet
I have a Sampo PME42x9 monitor that I am trying to get to work with my laptop. I set the input to RGB and hook it to the laptop and then use the Fn key with F8 and nothing happens. On the monitor it says...
The problem of course is not the computer since you communicate well when using the Samsung TV. The problem is your Sampo. The Video Ports are:
Composite Input (Shared w/ S-Video) RCA-pin x 2 S-Video Input (Shared w/ Composite) Mini DIN 4-pin x 2 Component Video Input RCA-pin x 2 Sets (Y/CB/CR, Y/PB/PR auto detect) DVI Input (with HDCP) DVI-D 24 pin x 1 RGB Input D-Sub 15-pin x 1
If the RGB WILL NOT COMMUNICATE, I suggest you try RCA/DVI/ or shared composite. You may need adapters, but with so many options, just try other methods.
Feb 06, 2018 | Sampo Computers & Internet
Desktop has no signal
That means that the input from the monitor has no read able signal
Either the monitor is bad or the onboard or video card
Take the monitor and hook it up to a different PC to see if it works or hook a different monitor into that PC, that will ID which problem you have
Dec 29, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
I want to use my laptop as a monitor for my desktop
Check VGA cord connection, possibly try another, shorter VGA cord, plugging in cords BEFORE booting up computer, with monitor power on also. No signal is just computer telling you that it is not connecting.
You may have to go into Setup when computer boots up and turn on or select external monitor as some laptops may require this. Good Luck!
This is a great place for solutions that will save you lots of $$$$. I love it and it is my first contact with FixYA! jaballou
Nov 15, 2008 | CMB T43 750 Notebook
Kindly give a brief discription of your problem...
Thanks and Regards
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
