Question about Canon GL2 Mini DV Digital Camcorder
I have a GL2 and need to get out the tape cartridge. My power Charger is not working and a I do need the tape. HOW?
  • 2,335 Answers
Some GL2's exhibit the behavior that if the clock battery is dead, they will start up in VCR mode but not in camera mode. Removing the clock battery will let the camera mode start up again. I realize this is not your problem, but it occurred to me that their might be enough juice in your batteries to start up in VCR mode and thus pop your tape out. (& I thought you could file the tip about the clock battery away.)
Barring that hope, there is no way to force the eject mechanism due to the motors required to manipulate the transport.
I am afraid you need to get power to your GL2 or have it taken apart by a tech.
I hope that helps.
Posted on May 08, 2010
How to chrge it?
You will need a charger like the one listed below. Just remove the battery and place it on the charger.
CA-920 Compact Power Adapter
This is the standard charger and power source for the GL2. It will charge one battery at a time.
Oct 03, 2010 | Canon GL1 Mini DV Digital Camcorder
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
GL2 Tape comes out pixalized
You may have a heavy clogging of the heads. The head cleaning tape will not serve in this situation but manual head cleaing from trained technician. Head cleaning service shoud go around $100. Same symptom would happen when the tracking goes off on GL2 and this may cost more to adjust. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 31, 2009 | Canon GL2 Mini DV Digital Camcorder
My canon gl2 won't record because it keep telling me to eject the tape. I put in a new tape and the samething keeps on happening. What can I do about it?
You may be the victim of dirty clogged head. When the tape is incerted on GL2, it is searching for the data from the tape but if the heads are clogged it will not communicate so, the processing computer think the tape is damaged. Procedure to clean the head. This may not clean but let's try. Purchase a head cleaner tape and run it for about 10 seconds but not more. Try to insert regular clean tape and try it. If this does not resolve the problem, GL2 need cleaning and adjustment by technician. Good luck -James. For further assistance email, go to www.camerarepairjapan.com
Mar 23, 2009 | Canon GL2 Mini DV Digital Camcorder
GL2 drops in blue tint or yellow blocks
Your GL2 has a case of clogged heads. If the clogging is minor, you can clean by using head cleaning tape. 1.Open the tape door and blow out any dusts present. 2. run tape cleaner for about 10 seconds but NO MORE. Hope it works. -James. For further assistance by email, go to www.camerarepairjapan.com
Feb 28, 2009 | Canon GL2 Mini DV Digital Camcorder
Canon GL2: eject tape/ condensation error... service locations??
Dear Sheryl Bahr
Hi!!!
The audio in 16 bits of my Canon GL2 is cutting on player (failling) after the recording.
This problem is intermittent.Please can you help me
My email adress is: ednelson.sm@gmail.com
Thank you
Ednelson
Jan 10, 2009 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 NO POWER, NO FUNCTIONS
Hi david;
There are a few floating around some of the forums but getting one is not going to be easy. I can see if I can find you one. Ill post here if I do.
Feb 04, 2008 | Canon GL2 Mini DV Digital Camcorder
GL2 does ne rewind
I doubt it is something in the settings. Step 1: The tape may be causing the camera to "reject" it. In other words, it thinks there is something wrong with the tape so it is warning you with the error message. Perhaps the cassette has been damaged slightly. This error can also happen when the tape has been used often or taped over a few times. MiniDV tapes are not media that can be recorded over and over again. Solution: Try using a new tape. 2. The camera may need to be cleaned. The recording heads may be dirty and it doesn't matter what tape is placed in there. Solution: Purchase a cleaning tape from a consumer electronics store. Make sure you read the directions very carefully. These are cheap fixes. If it works, great. It would also be good to know what it CAN do. Does it play in the VCR mode? Does it record? And can you view it in the VCR mode? Has it changed in any other way, i.e. is it making a strange noise when it starts to rewind, when before it didn't? Let me know how it goes.
Jun 08, 2007 | Canon GL2 Mini DV Digital Camcorder
Canon GL2 Mini DV Digital Camcorder Logo
74 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
