Question about Yamaha HTR-5790 Receiver
I was able to reset audio. Now I can not clear
I was able to reset audio. Now I can not clear the video OSD. It displays the the options from 1-18.
    Problem Solver:
  • 5 Answers
Are you talking about the * that go into the catagories? you should be able to select what type of surround you want via the manual test option and in the menus (sound menu?) you can select either 7.1 6.1 5.1 etc. or you can turn off the presence and turn on your surround rear settings (like it should be) so that you have 4 speakers in rear three in front and sub or two subs if that floats your boat. You need to be more specific about the OSD. if you mean reset by getting rid of the * on the 18 sound fields, then not having the * next to them means that they are set to the factory standard for that particular field. Which you can also select via the OSD on the receiver itself via the manual test method.
Posted on Sep 12, 2010
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Tip
Diagnosing video problems on TVs and monitors
The first thing to always check is the MENU (osd - on screen display)
Push menu or display on your tv or monitor
- if the menu is clear, the problem is in the early stages of video or outside your device (could be the source (dvd, cablebox) or input connections
- if the menu is distorted, the problem is definitely a malfunction with your device the osd is generated from (tv menu distorted = 100% tv is problem)
* you can also use other OSD signals to troubleshoot - if the volume bar or display info (input label, info bar) is clear, problems are earlier in the circuitry or outside the device. don't be fooled by translucent menus or cablebox menus.
** osd is inserted in the picture in the later stages of video processing. if your osd is distored, suspect the circuitry after the video switch. this could be a bad LVDS cable, TCON or Logic board, or even a bad lcd panel, plasma panel, crt.
on May 21, 2010 | Televison & Video
Receiver and tv connected with HDMI. I can watch tv and dvd but the Wii video will not go through. I can hear the Wii but no picture. I also cannot get the OSD for set up to show up on the tv. I worked...
I think I would try a reset first. With receiver turned on, press and hold the VCR/DVR button, then press Standby. the display should read "Clear".
Jun 11, 2010 | Onkyo TX-SR606 Receiver
I can't get the OSD display to appear on my monitor.
it's in the manual footenotes. osd will not work with an hdmi connection to monitor. it will work with s-video or component. just switch input when osd is desired.
Jan 28, 2010 | Yamaha RX-V661 Receiver
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
How do i do a full reset? I would like it back to factory settings.
Click on Start, All Programs and click HP My Display, Again Click HP My Display and than you can follow the on screen display to reset it.
Also you can use the front panel buttons
Power Turns the monitor on and to standby or sleep mode.
? NOTE: The power button is located on the top or front of the monitor depending on the model.
- Menu Opens, selects, or exits the OSD menu.
-Adjusts the volume level.
-Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text.
– Navigates backward through the OSD menu and decreases adjustment levels.
+ Navigates forward through the OSD menu and increases adjustment levels.
Auto Auto-adjusts the display
Select Enters the selected option.
Jul 30, 2009 | HP w1907 LCD Monitor
Avr5800 with no on screen display
With some receivers, the on-screen display is limited to a specific video output from the receiver to your TV.
I'm not 100% positive if that's the issue with yours, but it's likely.
If you're connected via Component or HDMI out, you may want to try S-video or composite video.
If that doesn't work, consult Denon to find out which output does your OSD.
Mar 24, 2009 | Denon AVR-5800 Receiver
OSD not working (black screen)
Your 635 will not display the OSD screen through component. You must use either s-video or rca. It won't upconvert the screen menu this route.
I had one up until a week ago. There are two outputs on the back specifically for the OSD screen. I used a separate old 13" TV with s-video to do my setups. Hope this helps.
Sep 04, 2008 | Harman Kardon AVR 635 Receiver
The OSD on my Harman/Kardon 347 does not show up anymore. I am using a Compostie cable and it just stopped working a while ago. I had hooked up an X-Box 360 to my T.V using the 3 RED, GREEN, BLUE component...
Put the receiver in stand by mode (amber light) and hold on the tone button for 8 seconds. This will reset the receiver. After it says reset, let go of the tone button and wait about 30 seconds. Then hit OSD and you should be good to go.
Jul 22, 2008 | Audio Players & Recorders
OSD
If you have checked thru the owners manual and could not find anything helpful for getting the OSD working again, you may want to try this reset procedure at the end of this post and then try to get the OSD working again. The owners manual should give instructions on how to activate the OSD.
This reset procedure will clear all the setting you have made, so make sure you know how to put those settings back in again before doing this.
If you do see the video from what ever video device you have connected to the unit (DVD player ect. ) but you don't see the OSD when you enter into any setup menu, then this reset procedure may help fix that problem.
If you are not seeing any video from the video device connected to the unit, then you may just have the wrong setting for the output from the video out to the TV. These Denon's are very complicated receivers (which you must know, since you own this receiver), and an improper setting can be causing the problems you have.
Befor eyou do this, go thru the settings menu and look for a OSD setting and see if it is turned off. If so, turn it on. If you can not find anything for the OSD try using the set up on the display of the Denon instead of the remote.
Here is the reset procedure:
With the unit turned off, hold down these two buttons at the same time:
Pure direct + Direct
while holding those buttons down, then press the power button to turn on the unit. Keep holding those buttons down for at least 3 seconds after turing the unit on and the display should flash at about 1 second intervals. then you can let off the two buttons and the unit is reset back to the same settings as when it was new. You now will need to put all of your custom settings back in to the way you need them.
Jul 09, 2008 | Denon AVR-3805 Receiver
Yamaha HTR-5790 Receiver Logo
70 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
