Question about Denon AVR-1508 Receiver
No video on Denon 1508
I am unable to get picture on monitor though sound from denon comes. My cable tuner is connected on coax2 and vidro output is taken from componet from denon 1508 to monitor
  • 1 more comment
  • praveenku729 May 10, 2010
    Thanks for your response.
    Output from cable tuner (hathway) is coaxial (one yellow video cable) one where the output from Denon is component. Component output is expected to be better than coaxial one. Hence the upconversion will improve the video quality..
  • praveenku729 May 11, 2010
    Thanks for update and your time.
    One correction from my side. I have 1708 and not 1508.
    Problem is, this upconversion was working earlier but not working now. Now I have connected hathway composite video output to AV of my Samsung LCD. It works. However, this restricts if I have another device say Nintendo V , to connect to LCD as number of AV ports are limited. Earlier, denon was doing this , multiple input one output to TV. Incidentally, even Nintendo V is not producing video output just like hathway.
    Fundamentally, problem remains. Interconnect is not working. Not sure how to resolve this. I am missing something. Or some configuration issue in 1708 or probably MONITOR component port of 1708 has gone bad.
  •  Aaron
    Aaron May 11, 2010
    Hello FixYa customer, I understand that you're using component out from the cable box to the component in of the Denon, and then component out to the monitor, but you are not getting the video. Is that correct? Is this a new setup, or did it recenetly stop working? Thanks
  • 25 Answers
If the "Video Convert" is enabled in steps 11-14 in the "Input Setup" menu, and you still do not get the upconversion, then either the Denon upcovert is faulty, the TV is set on an incomaptible resolution (this would be unusual), or the component input on the TV is faulty.
Eliminate the TV by verfiying the component input directly to the TV from one of your sources, if that works, and the resoluition can be changed at the source and dsiplayed on the TV , then the issue is with the UPConversion or monitor output of the 1708.
Thank you for using FixYa
Posted on May 11, 2010
    Brigadier General:
  • 8,546 Answers
Coax-2 is audio. Where's the video from the cable tuner coming into the Denon?
Why don you need the cable to pass video through the Denon on iuts way to the TV anyway? Interconnnects rarely add value.
Posted on May 08, 2010
  • David Dunn
    David Dunn May 10, 2010
    Composite is on the single Yellow (though technically it is a physical coaxial RCA cable it is not customarily called 'coaxial' in this context) and is the lowest quality video in this machine's pecking order. You couldn't make it any better simply by converting the protocol. All analog conversions lose something in the translation. The old saying goes GIGO. Garbage In = Garbage Out.
    I don't see anything documenting any kind of video uptick. In fact I saw one user review that compalined because it didn't have it.
    Page 11 in the manual:
    "AVR-1508's S-Video connectors (input and output) and video connectors (inout and output) have independent circuit structures, so that video signals from the S-Video connectors are only from the S-Video connector outputs and video signals input fomr the pin conenctors are only output from the pin connectors."
    I'd look for a better cable box video output (component or HDMI).
    BTW: digital cable doesn't mean HD. It could still be max 480i. Consult with Hathway on that.
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
No system configration display on AVR3300 since moving.
Make sure the S-video and the composite cable are not plugged in it the same time from the Denon of at the Plasma
Jan 19, 2009 | Denon AVR-3300 Receiver
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
No Picture on Mitsubishi v45605 rear projection tv
If it works the way you have it setup now, leave that way. Plug all your video sources to the denon if possible and leave it that way.
If the denon has the feature to change channels like a cable converter then you can use it or if you still have a VCR you can also use it as a tuner just to tune the cable channels and use the audio/video outputs from it to the TV or denon receiver.
The tuner might not even be available anymore and if it's, is expensive.
Good Luck.
May 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Denon 1508 A/V receiver; sound but no picture
I would try direct connection using a short SCART lead with full 21 way cable.
Feb 22, 2008 | Audio Players & Recorders
How to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Jun 21, 2007 | Denon AVR-886 Receiver
Denon AVR-1508 Receiver Logo
355 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
