Question about Kenmore 73952 Gas Dryer
Dryer starts aand gets hot for about 10min then the heat shuts off and will not come back on
  • Kenmore Master
  • 2,699 Answers
You have bad gas coils.common problem,the coils will work until they heat up then they fail,the coils are located on top of the gas valve,very easy to change,let me know how you make out,call your parts store and give them the model number and they'll give you the coils
Posted on May 08, 2010
  • Sal De May 08, 2010
    part number 12001349,that's for both coils
Poulan 2000 leaf blower shuts down after getting hot (7-10min)
Make sure your oil to fuel ratio is correct. You cannot run it on gasoline alone.
Oct 20, 2014 | Garden
Dryer will run about 10 minutes then shut off. Try to turn it back on and it just will buzz
Either a motor with bad windings,. or an over heating problem?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
GOD IS GOOD !!!!
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Sep 30, 2014 | Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Dryer heating then tumbler stops after 10min but keeps heating. I have tried cleaning out the lint trap already.
IS THE DRYER A SENSOR DRYER IF SO TRY PLACING A JUG OF HOT WATER INTO THE DRYER, BUT DO NOT EMPTY THE WATER IN THE DRYER, JUST LET THE STEAM OFF THE WATER OPEN THE SENSOR HOOVER DYERS HAVE THIS PROBLEM TO
Sep 23, 2010 | Bosch Axxis WTA4400 Dryers
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Jan 04, 2010 | LG DLE2516 Electric Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Dryer turns off after one minute.
Sounds as if your high temperature thermostat is going bad or is bad. Check your thermostats. If your dryer gets to hot this will shut it down for safety reason!
Jan 09, 2009 | Kenmore 66832 Dryer
Whirlpool gas dryer
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc.. http://www.pcappliancerepair.com/whirlpool-dryer.php#fuse
Hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Kenmore 73952 Gas Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
