Question about Amana NGD7200TW Gas Dryer
We just purchased a floor model of the NGD7200tw and we plugged it in and it works great. Except all the specs that I have read say it has a drum light and ours either doesn't have it or it's burnt out and we can't find it to replace the bulb! Help
  • 8,197 Answers
Sorry to tell you but you have no light in the fryer. If you do not have the manual you can download it on the link below. Just scroll down an type in the # code then click on download.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs up for the free answer.
Posted on May 08, 2010
Won't shift through gears. Won't shift into neutral. Clutch is working fine. Got it into neutral once started and ran fine. Just changed oil that meets all specs.
Hi Dennis did you drain the oil from the sump plug? Or is it possible you may have mixed up the gear position plunger. It's a similar plug except it has a spring and a ball to keep the selector drum in each gear.
Apr 13, 2015 | Motorcycles
Dryer drum off balance
Put a construction level on top of dryer, use a 3/8 '' wrench to adjust the bottom feet as needed, to bring the level bubble to the middle.
Jul 25, 2014 | Amana NGD7200TW Gas Dryer
Ngd7200
if you rapped the belt around the pulley and it's not tight enough then you popped the spring off of the pulley,you'll have to pull the drum again so you can see where the spring connects to the pulley,here's the sears site,put your model number in,click on cabinet parts and you'll see number 15 tention spring,this has to be connected to the pulley arm.http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NGD7200TW10/1268/0151200/W0712024/00002?blt=06&prst=&shdMod=
Nov 12, 2011 | Amana NGD7200TW Gas Dryer
I just purchased a new dryer from lowes, When I started it up I here a grinding sound. after looking closer I found the drum was rubbing on the moter. the purchase was a as is. floor model everything els...
make sure the drum is up on the roller on the right side,this roller slides back,touch it and make sure it's forward and is riding on the drum,if not remove the drum and check out the roller to see if it's damaged
Jun 20, 2010 | Roper REX4634KQ Electric Dryer
My GHWT for ps2 2nd guitar not working.
same problem here. and i found out that it is broken.
Feb 24, 2009 | Sony PlayStation 2 Slimline Console
My husband and I are building a new home with a second floor laundry room. We are very interested in purchasing a LG washer (WM2688HWMA) and dryer (DLEX8377WM), but need strategies to keep the units...
hi As a safety device, a dryer usually has a door switch that activates the working .A dryer is simply a large drum into which wet laundry is loaded. A motor with pulleys -- connected by a series of belts -- turns the drum. Air heated by a gas heater or electric heating element is blown through the drum to dry the laundry. The temperature and speed of the drum are controlled by a series of thermostats operated from a timer device on the control panel of the dryer.
The control panels on the latest dishwashers can look intimidating. They're loaded with so many dials, push buttons, and other features that the machine looks too complex to repair. This is actually not the case. With the exception of the control panel, dishwashers haven't changed much in basic design over the last two decades.
Sep 12, 2008 | LG Washing Machines
Amana NGD7200TW Gas Dryer Logo
406 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
