Question about Sony Computers & Internet
Does a PCG-V505AX have to have a battery for power supply?
    Novelist:
    Champion:
  • 226 Answers
Absolutely not. It should work with battery only, AC adapter only, or both.
Posted on May 08, 2010
Sony pcg-81114L power supply not detected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 04, 2012 | Sony VAIO PCG-K33 Notebook
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
Vaio pcg671l lost external power (no problem for the power supply cord, work well wit battery). I am looking for a compatible docking station as external power instead.
hi
hi. I would like to suggest you get these parts are offline, because it's easy for you to test before buying {make sure you match the parts before buying}
regards
May 15, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
HI my battery doesn't charge anymore. I'm not sure
battery is out....
change battery...the battery wears out with frequent charge and discharge...it has a running live of some 15000 to 20000 hrs
Dec 14, 2009 | Sony VAIO PCG-V505EC Notebook
Sony Vaio PCG-K33 will not power up
Hi
Ensure battery is secure, If so try removing it and plugging power supply in.ensure all power supply plugs are very tight and fitted, unplug each one and re-plug in to be sure. Sometimes the power supply lamp can be on but not actually supplying power out the other end.
Aug 17, 2009 | Sony VAIO PCG-K33 Notebook
Wont boot up when plugged in but boots from battery
When you plug it in, does it show that the battery is charging? If not, then the DC Power socket has failed on the laptop, so a new power supply would not fix the problem.
The manufacturer will tell you to replace the motherboard, however the DC power sockets are readily available, and relatively easy to fit.
Mar 05, 2009 | Sony VAIO PCG-K35 Notebook
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
Nov 16, 2008 | Sony VAIO PCG-V505CP Notebook
Computers & Internet Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
