Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Where is the lamp located on a 61'' RCA Scenium? Model # D61W130. From what I have read on here it seems the lamp needs replaced but I cant find it.
snakehead
  • 1074 Answers
SOURCE: rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Posted on Mar 30, 2007
  • 395 Answers
SOURCE: The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Posted on Feb 06, 2008
SIGDOM
  • 17 Answers
SOURCE: RCA HD Ready 61" scenium
because it makes buzzing sound at power off and blinks blue lights at the bottom,sounds like color weel problem.if you take out the color weeel you may see it partly broken.
Posted on Apr 06, 2008
  • 18 Answers
SOURCE: dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Posted on Jan 15, 2009
  • 41 Answers
SOURCE: i have a 61 inch rca scenium dlp tv. the picture
Change the Lamp.
Posted on Apr 19, 2009
RCA Scenium turn on tv with remote, on light flickers on and off
You'll probably need to replace the lamp, the approximate life of a lamp is between 4000 and 6000 hours depending on owners use. You'll find the lamp located behind the access dorr in the right side of the back cabinet, two hex screws hold the access door in place and two more hex screws hold the lamp cage. Once the screws are removed pull the cage assembly out and check the lamp side, you'll probably see the damage in the center of the lamp. If the lamp is the problem, you can find a goos selection at UED union electronic distributors, you can contact johnl@ued.net and provide him with your model number.
Apr 28, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Rca scenium 61 inch dlp
This unit has a bad colorwheel
Jan 12, 2009 | Televison & Video
RCA Scenium d61w130 turns off then on
I installed a small cooling fan in the back ot the TV. It was overheating. Fixed the problem.
Nov 22, 2008 | RCA D61W130 61" Rear Projection Television
Rca scenium turns off and on
I had the same problem with mine. It was overheating. I installed a small cpu cooling fan on the back of the unit. No problems since. Good luck.
Mark
Nov 08, 2008 | RCA D61W130 61" Rear Projection Television
Tv turns off after a few minutes
I had the same problem with my D61W130. It would turn off and on intermittently. Called a TV repair shop and they said this model was known for it's poor soldering connections on the power board. They came out and took it apart and re-soldered the board. It cost me almost $300 bucks but it seems to have taken care of the problem. It's working great now.
Oct 31, 2008 | RCA D61W130 61" Rear Projection Television
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture
Assuming that the replacement lamp is good, you could be looking at a bad ballast (lamp power supply) or the switch on the lamp door itself could be causing the issue. The light engine also could cause an issue like that. I would have a technician look at it as this is beyond consumer repair.
Nov 25, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
