Question about Brother PT-1750 Thermal Label Printer
Brother PT-1750 won't turn on. New batteries were
Brother PT-1750 won't turn on. New batteries were inserted correctly and still will not turn on. Help please.
Will not turn on
Welcome to the Community. Press the F2 key at the Dell Logo on startup to load into the Bios, and check what does it say next to AC adapter, if it says unknown, try another working adapter. If the working adapter works then its an issue with your ac adapter, if it says unknown in the BIOS then its a motherboard failure. Still having Problem Then follow Us For
Brother Printer Support
Mar 23, 2014 | Brother PT-1750 Personal P-Touch Labeling...
Won't turn on after changing to new batteries
Did you put the batteries in correctly? It could be that simple.
Mar 20, 2014 | Brother P-touch PT-90 Personal Label Maker
P-Touch Model PT-65 won't turn on when pushing On Off Button
Brother P-Touch Home & Hobby PT-65 / BRTPT65
(PTouch, P Touch, PT65, PT 65, BRTPT65)
Answer from
Posted by Tiffany Marsh on Jan 20, 2013
http://www.fixya.com/support/t16011345-p_touch_model_pt_65_won_39_t_turn_when
Replace the "Toner Sensor PCB Assy" model # LJ9935001. It is located in the left side panel which is easily removed (2 screws).
"I have solved my own problem, I have a second identical printer that just developed the same problem, so this seems like a common problem. The solution was to replace the "toner sensor pcb assy" model # lj9935001. It is located in the left side panel which is easily removed (2 screws), I had it replaced in half an hour and that was the first time. It clips in ,the wire needs threading a little then then connector . if you take your time and think it through it is easy then turn it on and presto nothing but green status light. costs $18.50 with shipping ground. Contact Brother 901-379-1000, get customer service and ask for parts dept. Best of luck."
I found the the Toner Sensor PCB Assy" model # LJ9935001 for $9.89 just by searching through Google and Amazon, so shop around, $18.50 is expensive when you can buy a gently used PT-65 on ebay for $10 - $25.
Jan 20, 2013 | Brother BRTPT65 PT-65 Label Maker Printer
How to print backslash character on P-touch labeler
Use Format - Mirror - and select / . The slash will be reversed.
Mar 26, 2012 | Brother PT-1750 Personal P-Touch Labeling...
Have inserted new batteries and new cartridge but not able to print
Sounds silly, but are the batteries good and are they correctly installed. Check the pictogram in the battery case and make sure that the batteries polarity complies. Also check that the cartridge is securely fitted and the tape feed is correct.
Jan 17, 2011 | Brother P-touch PT-80 Label Printer
How do I change the font size on my p-touch 1750??
The shift and up keys together make larger type, while the shift and down keys together will make smaller type.
Oct 29, 2009 | Brother PT-1750 Thermal Label Printer
Unit won't turn on -is it dead?
I had a problem in that I purchased cheap batteries. Brand new out of the box at least three were bad. Confirm your batteries are OK by using them in other electronic items. Even one battery too weak or bad will cause a problem.
>I'm also assuming that you have correctly replaced all the batteries back in the PT65. My mother always puts one battery in wrong and needs help. LOL...
Apr 26, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Brother PT-1750 Thermal Label Printer Logo
387 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
