Question about Bosch Dishwashers
I ordered a stainless steel door panel (SGZ1005UC) for my Bosch dishwasher (SHV45M03UC) and the installation instructions are minimal and the diagram does not match the door. I can attach the handle, but do not know if I should remove the partical board that is in the door when it shipped. Also, there are no pieces protruding that I can see for attaching the door.
  • Anonymous Mar 22, 2014
    How do I remove the door panel? (to replace a chipped panel).
Did you ever figure this out? I just got the door and have the same questions!
Posted on Jun 07, 2010
Schematics/Diagram for Bosch SHE68M05UC/50
The last two Bosch Dishwashers I have owned, the detailed schematics were rolled up tight and placed in behind the left front foot rest.
Jan 18, 2013 | Bosch Evolution 800 SHE68M05UC Stainless...
Is there a stainless steel door panel replacement for bosch dishwasher shx43c02uc
If there isn't, you might try having a local metal shop cut you a piece of stainless, fold and weld the edges to make a cover for the door and adhere it either with epoxy or a small tack-weld. I wound up having to have a cover made for my Mom's stainless-steel fridge when only white and black ones were available and a metal shop doesn't charge much for it.
Alternately, if the metal panel is housed in a frame, try taking apart the frame, removing the panel and flipping it over. They usually just paint the one side, and if the other side is bare metal, such as aluminum, you can use sandpaper to give it a brushed finish and some clear-coat spray paint to give it that shiny stainless look and durability. Then just reassemble the door with the stainless-looking side facing outwards and the wrong-color side facing in. Worked for Mom's dishwasher!
Aug 31, 2012 | Bosch Dishwasher Door Panel White - 245067
Replace Bosch SHU3306UC door panel with stainless steel?
Instead of replacing the entire door.
Go to http://www.applianceart.com
These guys offer every solution imaginable for refacing your existing dishwashers. They make dishwasher covers in a variety of designs, textures, solid colors and stainless. Check out their website and if you still have questions get in touch with these guys. They are able to walk you through all the available options and keep you from having to replace the entire door.
Jan 20, 2012 | Bosch SHU3306UC Built-in Dishwasher
Can I exchange the white door panel for a stainless steel panel on Bosch Dishwasher SHU5312UC/U11?
from my research all but 3 models have that option, I didn't see yours there, But if you contact sears or www.homeeverything.com I'm sure they can assist you
May 18, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
How do you mount a wood door on this dishwasher?? Archie
Bosch offers a kit for installing a wood panel in place of the normal outer door panel. Based on the limited amount of clearance between the bottom of the outer door panel and the toe panel, I would suggest using the kit offered from Bosch. You will also need the last 2 digits of the model # to get the correct kit. After the UC, there is a /, followed by a 2 digit number. This is also needed.
On a further note, you may also need stronger springs as a wood panel is much heavier than the normal outer panel. You do not want the door just falling open, it is a good way to bend the door hinges.
Apr 29, 2011 | Bosch SHV45M03UC Built-in Dishwasher
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Can I get a different front door for my dishwasher?
From what I could gather, it appears that there may be a door panel kit available for your dishwasher. The kit appears to have the panel kit and the curved handle included. Some links for visual reference:
SGZ1005UC Stainless w/tubular Towel Bar Handle
SGZ1006UC Stanless w/curved Handle
Feb 06, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosch SHV45M03UC dishwasher door leaking
the latching mechinisum is at fault or the door is bent.
Apr 07, 2017 | Dishwashers
Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Sep 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
256 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
