Question about Toshiba E-Studio167 Copier
Remove bad paper
How can i open the copier to remove bad paper?
  • 75 Answers
You should see
e studio see from top to buttom see the locks and screw cafrefully then find some screws then open them
Posted on May 08, 2010
Paper jam in this position
Open the machine as if you were putting in a new cartridge and remove the jammed paper. You may have to remove the paper tray or duplexer to find more paper.
Reassemble, don't put so much paper into the tray, make sure the paper isn't curled badly. Generally I put the paper in concave down...it will flatten over time.
Perhaps your paper is curled somewhat and is concave up which is causing the jam.
Jun 25, 2015 | Office Equipment & Supplies
CM2320 MFP PAPER JAM
Bad problem , check if there is some piece of paper ... otherwise yuo need a thecnic , may be is a paper sensor damaged .
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
Error code C0910
Second Draw lift open the second draw remove the paper from behind the draw, ALSO REMOVE THE PAPER BEING STORED ON LEFT HAND SIDE OF THE DRAW. IT IS NOT A STORAGE AREA!!!!!!! It is available for 11xx17 paper. Storage is for the storage draw!!!!!!, IF not these two items you have a bad motor for the second draw or worse case a bad control board!!!!$$$$$$
try this site for parts:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 21, 2012 | Minolta DI2510 Black and White Copier
Misfeed in the in the automatic duplexer
open automatic duplexer door you will see 4 parts to open and green ring for rotating. rotate it the jam paper it will removed. or open all 4 parts you will see the paper if not open drower and remove the paper jam,
Jul 29, 2010 | Toshiba E-Studio 3511 Color Copier
Stuck papers
Remove or open the right side cover of the copier , you will see the drum and the fuser unit. Press the two green levers on the fuser unit one on right and the left one down and look for a paper. If its stuck , open the front cover and turn the green knob. Remove the paper tray and check the inside of the copier and then arrange papers well.
Jan 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
Paper jam message does not clear after paper jam has been removed
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
Jan 08, 2010 | Canon imageCLASS D480 Black and White...
I have a Dell s200n printer, the green light bleeps and states load/ remove paper, I have tried loading new paper removing etc however nothing works, I have reset the machine and still the error stays, can...
you have a paper jam or a bad paper sensor. open the back/rear and look for ajam in the fuser. if no jam you have to call a rinter tech to find the bad sensor
Dec 30, 2009 | Dell S2500N Printer
How do i remove misfed paper?
I hope the there will be an indicator that wil tel you the position of the moisfged paper,
unplug the copier from the power socket, open the indicating unit and remove the paper, do not force the paper anti-clock, pull the paper through the normal running of the paper.
Jowinson
Jun 20, 2008 | Panasonic FP-7750 Black and White Copier
Toshiba E-Studio167 Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
