Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
After stopping, tractor does not engage in forward or reverse
After running fine for an hour, stopped for lunch. Started tractor up again, turned on blade, but tractor would not engage in forward or reverse. Seems locked up somehow. Pushing the forward or reverse pedal results in wurring sound, but does not engage.
  • bturner950 May 08, 2010
    Negative. If you mean the "rod bypass", it is not pulled out. But I believe you're onto the problem. The rod was pulled out during winter storage, then engaged when operating the first time this season. Pulled it out again after operation to push the machine into shed. Since then the wheels remain locked whether the rod is in or out.
  • 472 Answers
Sounds like the by pass rod has been pulled out
Posted on May 08, 2010
Starts, runs, moves forward and reverse just fine. Try to engage blades, engine stops
It is a neutral safety switch that has a problem. is what i can tell from the little information that you have given
Apr 29, 2015 | Garden
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
No forward/reverse motion
This sounds like you have a bad bearing in one of the blade hubs or idler pulleys. Check by turning each pulley by hand and see if it turns easily. Go around all the pulleys and blade hubs(where the blades mount) and check for ruff spots while turning, and that they all turn freely. Do this without the blade engaged, this will allow them to turn somewhat freely.
Apr 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My caterpillar D7F was shifting forward and backward one day we came to start the machine it wouldn't engage in reverse after sometime it stop engage forward. what could possibly be the problem?
This could be a very simple fix to an oh my god. First check your fluid levels. My initial thought is how it slowly started to stop shifting is that you need to fill your transmission fluid. If that is the case after it is full then you will be able to shift fine. Second part of your problem then is finding out where it is leaking and get that fixed. If it is just a leak count your blessings, fix it before using it again and always check your fluid levels often.
Nov 12, 2012 | Mitsubishi WD-62528 62" LCD HDTV
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Transfer case /fuse/software for transmission?
thawed it out the next morning-reset codes to standard-viola-all is well. seems ice found its way into switch@transfer case and ran the chips riot-sending tranny into limp mode. cold weather,rrrrrrrrrrrr. june can't come soon enough.
thanks anyway
Jan 29, 2009 | 2003 GMC Sierra
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
832 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
