Question about EliteGroup P4VMM2 Motherboard
After setting the bios for formatting my ecs p4vmm2 v5.0A hangs up what could be the problem and solution for this problem pls help me...
  • 3 Answers
I had that motherboard, wasn't happy with it at all.
But you can flash the BIOS if you want . Make sure you download the correct BIOS version. There are like 10 versions for P4VMM2. I chose the wrong one last time my system didn't boot. I threw the motherboard away, purchased an Intel Motherboard.
I'm not a ECS fan at all. Use AMI flash utility , flash the BIOS under Windows.
Posted on Sep 04, 2010
Reformat and i lost my sound/audio p4vmm2 is my model and ECs manufacturer.pls help wer i can find the installer for my sound card.tnx
After you reformat, you need to reinstall all the motherboard device drivers. You can find your device drivers here:
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=p4vmm2
Please check your motherboard for the version number as there are several versions of this particular motherboard. Select that version and download the drivers you need.
Mar 23, 2011 | EliteGroup ECS P4VMM2 Supports Intel...
I have an ecs board p4vmm2, cpu fan is running but i cannot install the os it hung up...any help pls?
Make sure you have the correct memory speed for that motherboard. Also go into the BIOS and set everything to default.
Apr 26, 2010 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Ecs p4vmm2 v1.0 motherboard windows xp sp2 can`t get sound to work onboardsound
1st: try enabling the onboard audio devices from the bios setup menu. it should be somewhere in the on board menus.
2nd: try installing the latest drivers from ECS
i did not manage to find the motherboard model you specified. i did manage to come up with these:
p4vmm2[v1.1] drivers http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=Driver&DetailDesc=P4VMM2%20%20(V1.1A)&CategoryID=1&MenuID=82&LanID=0
and also p4vmm[v1.0] drivers
please re-check the specific model you have and download the driver that suits you
Mar 02, 2009 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
I want my display drver
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1704&areaid=2&LanID=0
thats the driver for the intergraded video on a ecs P4VMM2 motherboard
Driver Name : S3 ProSavage Display Driver P4M266_KM266-P
Nov 27, 2008 | Computers & Internet
Comp doesnt boot after installing USB 2 drivers
Hi rogueonline,
Disconnect the external drive from the PC. (It's possible windows registry is messed up).
It sound like your windows system is a bit confused as well. First try resetting the bios. See page 9 in your manual. (Don't forget to set it back to normal). This should allow you to get back into the bios. Go over each setting & adjust as needed.
Make sure your primary hard disk drive is listed in the boot order. Advanced Setup Page 30, in manual. If your windows operating system seem is a bit off (OS not installed correctly or driver software not installed correctly). The over-all function of the system can & will run slow. If your primary drive seem to also run slow, the FAT or MBR can be slightly corrupt which will also slow the drive down including file transfer & eventually the drive will cease to function. (The drive can be repaired by doing a full format through windows).
Do a fresh install of windows, including the full format, (Not a Quick format) on the primary drive. Even though ECS does include the USB 2.0 driver so does windows update service. If your windows was all ready updated & you re-installed ECS's (2003) USB driver, that may have been enough to screw up windows. If you have data on your current drive & need to get that data off & if you have access to another system you can pull your drive & slave it into another system & remove the data. There is no quick fix. Play it safe. Start from scratch. After windows has been installed & you install the ECS driver software, update windows until there are no updates left. I'm sure your system will regain its speed.
Link to ECS web site for P4VMM2 V3.2A .
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Driver&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Good luck ogueonline!
Mike
Nov 03, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Can this board support 1m L2 cache?
Your manual will tell you what the motherboard can support . If it a pre-manufactured motherboard ( A.K.A a dell , gateway , sony vio , HP .. ect ect ) then more than likely the answer is NO
Jul 26, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
My ecs p4vmm2 cannot open to windows
you must have a faulty floppy disc unit, you need to press F2 or Del to get into the bios and check the time and date if they are wrong then the cmos battery needs changing.
Sep 11, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
112 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
