Question about Panasonic DVD-RV31 DVD Player
Stuck on READ for about 30 seconds, then goes to HO2, then goes to STOP.... cant get to play the DVD or even let me get to menu or anything.. will only recognize on and off commands
3 Suggested Answers
zair
  • 82 Answers
SOURCE: My DVD disc not recognized after loading, how can i fix it?
Spindle motor is defective.
Posted on Feb 16, 2008
SOURCE: Panisonic DVD RV-31 Wont read
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VERY CAREFUL NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knackered and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Posted on Feb 03, 2009
Has dish tv started to stop people reoding dvd,s of there tv programs
if your saying you have a dvd recorder hooked to a dish box and all its recordes is black then id say your recorder is either not connected proper or your dvd recorder has a problem
, me I cant see why you'd do this as dvd's need to be finalized before viewing , why wouldn't you use a DVR as they don't require any finalizing before viewing
Apr 09, 2016 | Televison & Video
My DVD player won't play i'm getting a code HO2 on the display screen. ModeL # DVD-RV31
this is what i got from Josh Smith Online, this work-around requires opening the appliance, so before you start and follow this, please check on the warranty status of the unit.
error HO2 which more or less means the unit is shot. The problem centers round a spindle issue that is a known design flaw. Basically what happens is that the spindle gets warm, expands, and is then pushing on the top of the player .
You can see the tray which rotates with the DVD in. To fix this HO2 error I first had to start the spin by pushing the dvd counterclockwise gently. After that the DVD player would work but only without the cover on. This is the solution for now, though I plan to modify the case some in order to use the cover again. For now the DVD player slides into our entertainment stand and hides the fact that the cover is missing.
Aug 11, 2008 | Panasonic Televison & Video
Beeping while DVD is in
Hi Rosanna,
Actually when a dvd is being read by computer, much of the memory is being used in it. if there are some unreadable sectors on dvd which ur computer cant read, it freezes i.e. it stops responding to anything & u think its hanged.
Even for sounds, either it stops the sound or it hangs the sound like grrr....
Try to clean the DVD with a soft cotton cloth with a bit of after shave over it.
Try it then..else try some other DVD's.......
hope it worked u out
Thanks
Aug 27, 2009 | Acer Aspire 5335-2257 Notebook
Mine wont play anything a DVD it recorded it wont let me finalize
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jul 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Cant play dvd cd or even eject the disc that is already in .
actually it is due to faulty disk or dirty lens sometimes , when the lens is dirty it keeps on trying to read the data from cd or dvd and it just cant stop that infact stuck in it , or the other reason is faulty loading gear , in either case u have to physically dis assemble the player , remove the top cover some 4 or 6 screws are there in place open the top cover see the cd /or dvd and remove it physically do not force anything hard when removing the media and then if u can see the lens of ur player just clean it with a soft cloth with ur fingers in cicular motions very gently and u will see that it will play dvd /cd fine , the other thing if the loading gear is faulty or broken then u can ask me more on this
Pls rate me WELL !
Jul 04, 2009 | Pioneer AVH-P6500DVD Car DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Magnavox MDV560VR DVD Player Stuck in Progressive Scan
Trun the DVD player on till you see the "progressive scan" screan. Hold the "stop" botton down for 5 seconds and the unit should reset to standard DVD play.
Worked for me, good luck.
Bill
Mar 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Dvd ho2
The problem centers round a spindle issue that is a known design flaw. Basically what happens is that the spindle gets warm, expands, and is then pushing on the top of the player . The following link shows a cheap fix..Hope it works for yours.
http://www.imjosh.com/?p=247
Jun 13, 2007 | Technics SCEH790 CD Shelf System
Display message HO2.
Hello, though I think it is a temporary solution you can try this:http://www0.dealtime.com/xPR-Panasonic-DVD-S35S~RD-228464823940 Best regards, Arpi
Apr 27, 2007 | Panasonic DVD-S35S DVD Player
Panasonic DVD-RV31 DVD Player Logo
21 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
