Question about HP Pavilion a1610n PC Desktop
The PC starts normally and runs for about fifteen or twenty minutes and then it shuts down and restarts. I checked the fan and it is working properly.
    Guru:
  • 109 Answers
Kindly Get the SMPS (Switched-mode power supply) checked. Its malfunctioning.
Posted on May 08, 2010
Dell studio 1737 laptop takes about fifteen minutes or more to boot up
Shelisha, may be you have too many programs to start with. That slows you down. Also extensions take time too. Try cleaning up and keep most used. Rest can go into a folder. Clean registry and clutter. I use advanced uninstaller pro. Have you defragmented the hard drive(s).
Mar 22, 2014 | Computers & Internet
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
Since your PC is two years old its recommended to check your computers hardware check your cooling fan
specially CPU cooling fan if that fan is broken your pc wont work and be careful turning on your PC again and again will burn the processor
Aug 04, 2011 | Computers & Internet
2001 Volvo S80 cooling fan runs for about 30 minutes after turning off the car.
This is normal. The fan will run even after the car is shut off until the engine gets below operating temperature. Most vehicles will do the same thing. Although I think thirty minutes is an excessive amount of time. Most could run up to fifteen to twenty minutes. If the car is retaining heat somehow this would cause it to run longer. Happy motoring!!!
Apr 13, 2011 | Volvo S80 Cars & Trucks
The car runs great but when I shut off the engine the fan continues to run. How can I get it to shut off?
The fan is controlled by a thermostat, it will (should) shut off by itself after a few minutes, after the engine has cooled down a bit.
If it continues to run after about ten or fifteen minutes (i.e., it does not shut off at all, and will run the battery down if you leave it overnight), then most likely the fan relay is sticking on, and should be replaced. Less likely is that the fan thermostat is bad.
But if it turns off by itself after about five minutes, this is normal and desirable, it gets some of the excess heat out of the engine.
Aug 23, 2010 | Jeep Cherokee Cars & Trucks
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Dell Dimension 8400 locks up after 15 - 20 minutes of use it doesn't matter the applications that are running. The start button must be pressed and held for a few seconds to power down the unit. It will...
Sounds like an overheating problem to me. Try taking off the side of the case, and starting the unit. Pay close attention to the fans that you can see. leave the computer running, and continue to check the fans. If a fan is going bad, not working, or going to slow, then the processor will overheat, and shut off the computer. Bad fans are easy to replace, just make sure you get the right size, with the right plug. This is just one possible reason for your problem, a further troubleshooting of the unit is needed...possible bad RAM, or video card failure can cause this mysterious shut down.
Aug 04, 2009 | Dell Dimension 8300 PC Desktop
2001 honda civic bogs out after driving for fifteen to twenty minutes
Check the EGR valve. If this valve stays open all the time like it sounds like it is you will have all these problems you are talking about, also with the glowing of the intake would make even more since
Jun 02, 2009 | 1990 Honda Civic
Acer Laptop random shutdown
i think the problem there is the laptop's overclocking too excessive try resetting bios or in their words set it to default
Nov 18, 2008 | Computers & Internet
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
HP Pavilion a1610n PC Desktop Logo
41 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
