Question about Kenmore Elite 45986 Front Load Washer
What does the F9 error mean on the Kenmore Elite HE3 42832
  • yadayada
    yadayada May 11, 2010
    it means call Sears.
  • 15,935 Answers
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Posted on Sep 25, 2010
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
A code F9 appears periodically what does that mean
The F-9 error code indicates a defective control board, inverter or line voltage too high.
You can also visit the link to troubleshoot the issue.
http://www.ehow.com/how_7987910_troubleshoot-code-f9-kenmore-microwave.html
Mar 03, 2011 | Kenmore Microwave Ovens
What does the code F9 means on a Kenmore Elite Microwave oven model 721-62362 manuf on March 2003
Read more: http://wiki.answers.com/Q/What_does_the_code_F-9_mean_on_a_Kenmore_Elite_Microwave_oven#ixzz1FMSrTmbU
Hope that answers your question and it won't be too expensive.
Check on ebay for prices.
Mar 01, 2011 | Kenmore Microwave Ovens
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
I have a Kenmore Elite Mod 721.63683300. At first I would occasionally get an F9 error once every 5 or 6 times I would use it. Now, I no longer get an F9 error, but power is reduced to about 50% as...
No, the magnetron gets its power from the inverter assembly. The actual issue here is a defective or damaged inverter. Replacing the inverter assembly will correct this issue.
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Kenmore microwave trouble code F9 what does this mean
Received a F-9 on my kenmore microwave. Nothing heats up amymore. Any suggestions on how o fix.
Dan
Aug 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What does F9 mean on a kenmore elite washer and F6
3-21-09 look at the gentleman site called "KC washer on now that is what is my continued problem now we are having enver ending issues with out of warrentee and replaced by sears many times the eniter panels: the ror codes are listed www. repair clinic.com and it listeed the sears or kenmore or whirlpool all the same manafacturersd if yuu iddnt know it under whirlpool trouble codes f9 is overflow condition check the drain hose
check wire harness connectors to the drain pdump oressure switch & ccu control unit
next clean the drain pump fil;ter of any objects ue shop vac to **** out water check drain pump the door is stsaying locked am i right? press cancel twice to clear the unit and unplug at this timedaniel440@verizon.net
Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
F9 Error
You can find exploded views and order parts by entering your model number at the Sears parts site.
Dec 06, 2008 | Microwave Ovens
Kenmore elite ultrawave microhood combination error code F9
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 22, 2008 | Kenmore Microwave Ovens
Kenmore Elite 45986 Front Load Washer Logo
160 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
