Minolta CF900 error code C0920
  • Anonymous Jan 07, 2009
    c0920
    Scholar:
  • 141 Answers
This problem is relate to one of your paper cassette probably the second one....
Try this : power off your copier, pull out all the paper cassette and then open your copier when it's done wait till your copier show ready or your error code, then open your front door and close it right away....After, pull just one paper cassette in it and wait to see if your paper been brought up, if so try the 2 one and so on....You probably have a bad mechanism to bring your paper up.....With this method you'll be able to see witch one of your cassette have a problem ! With that you'll be able to make your copier working again, just to leave the defective one out of the copier.....
Thank you !
Posted on Mar 27, 2008
Error code C0820 Call for help
This code don`t exist in Minolta .C0920 is first drawer lift up motor failure.Open and close the front door or set the power switch to OFF then ON.
Mar 19, 2009 | Minolta Di3510f Bizhub Copier
C0920
c0920 is the 1st paper drawer motor.
since the paper jammed the motor path, so the paper deck cannot come up, just pick up the paper n re insert the paper deck..problem solved..
Jan 19, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta CF900
try and locate botton called ACCESS.on the OP Panel should be pressed after you enter you access code
hope that help ...if not try the START BOTTON
Jan 11, 2009 | Konica Minolta DiALTA CF910 Copier
Minolta CF900 code C3250
CAUSE: Worn mylar.
SOLUTION: Refer to bulletin 3135 which pertains to the transfer drum joint Mylar.
If you can find a Konica Minolta dealership that can get the part or have tech come out and look at it A VETERAN (NOT MILITARY)Tech you have legacy Minolta now Konica Minolta, CF was first generation color. The mylar is dealing with the Transfer drum the big clear drum next to the drum.
Oct 20, 2008 | Minolta Office Equipment & Supplies
Description:
Intermittent C-3250, C-0210, or C-0230 codes occur during pre-drive.
Solution:
CAUSE: Worn mylar.
SOLUTION: Refers to the transfer drum joint Mylar.
SOLUTION: Replace the mylar (P/N 1144-4511-02)
hope that help
Oct 20, 2008 | Minolta EP1031/1031F CS/PRO Copier
Minolta cf900
High Voltage discharge to a electrical holder, there was cover developed for this problem, i don't know if KM has parts for this legacy machine
Aug 24, 2008 | Office Equipment & Supplies
Minolta cf900 maintenance tips
Dear Laker31,
you can find the right Tips ,on this Site:
http://solutions.konicaminolta.com.au/intranet/tsg/training/msds.cfm?b=CF900
Cheerup and Be Happy Always
Mar 14, 2008 | Computers & Internet
Minolta CF900 error code C0030
The C0030 is referenced to the developer drive motor for the 4 developer units.
you may need to replace parts.
BUT check the oporation of the unit FIRST. LOOK BINDING IN THE DRIVE UNIT
HOPE THAT HELP
Feb 15, 2008 | Minolta EP1031/1031F CS/PRO Copier
this is not a ricoh,, re code this issue as minolta nd you will get a ready answer...it is in the back of he usermanual
Nov 29, 2007 | Ricoh 6513 Copier
Minolta CF900 Photocopier
CODE C0900, DOES NOT PASS COPY, FIERY FRONT COVER BROKEN OFF AND VERY DIRTY, also you may want to try and look at the 3rd drawer lift perheps there's somthing blocking it
Aug 29, 2007 | Konica Minolta DiALTA CF910 Copier
252 people viewed this question
k24674
jasbo
jasbo
