Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Mower will not start a bag caught in the blade but that didn't seem to harm it, but to get the bag out I shut it down and removed the safety plug and turned the mower just up enough to get the plastic bag off the blade, then put it back down, put the safety thing back in and now it won't start. Curiously, the safety thing won't go in all the way, but it seats down, if I push on the start handle, so it's like there's something funny going on at that point. But, once I seat the safety thing that way, and then turn the main switch on and off, making sure to properly operate the safety bail as well, it still won't start now.
  • robhowe88 May 08, 2010
    Sorry for my rating, I appreciate your efforts to help, thank you very much. I should have mentioned, perhaps, that this is an electric rechargeable mower, so I don't have to worry about gas and solvents and stuff. The instructions say the battery has no fluids to leak and it can be stored in any position. I guess I posted this under the 19" electric rechargeable mower product. Thanks again, I appreciate your help!
  • 2,100 Answers
Did you lift it high enough to get oil into the cylinder? It will seep back down but the plug may need to be cleaned up a bit. You can soak it is solvent, laq thinner, gas, or bake in the toaster oven, But the wife might not like that idea. Get it back in there and give it a spin, see what happens. You might have to do it a couple times. As far as the safety thing, I don't know what happened there, But I think you may have pulled it one way or another too far when you tipped it up. Hope this helps.
Posted on May 08, 2010
  • Ned  White
    Ned White May 08, 2010
    I didn't even look at the top heading there, I was looking at the picture. When you said main switch, I said what the heck is that, but with all the safety stuff they put ion machines now days, you never know. Well, now you know what to do with a gas engine. As far as the electric one goes, it has to be something with the safety switch in the handle you spoke of, But I don't know what. Unless the reset button was tripped and you didn't know it.
My lawn mower blade has stopped discharging into the bag?
Turn the mower off and allow it to come to a complete stop or unplug it. Make sure the internal rear deflector is in place by lifting the rear door. Otherwise, the grass may get caught in the rear opening and cause the mower to malfunction.
Lift the door on the side of the mower. Look for the hooks on the underside of the door.
Line up the hooks on the door with the slots on the side discharge chute. Lower the door onto the chute. Grass clippings will now exit through the chute during operation. To remove the chute, reverse this process.
May 27, 2018 | Garden
Won't power up when clutch is engaged for mower deck
Something is binding in the mower deck area, perhaps and stuck bearing, bearing needs greased, stick or stone or big clod of grass caught between blade and deck or belt and pulley..
Disconnect to spark plug, and use a stick or something to spin blades manually. MAKE SURE spark plug is disconnected before EVER messing with blades. Motor could spin one time around accidentally and cut off your fingers. Disconnect plug wire and or remove plug to be absolutely sure before messing with blades. I'll say it again REMOVE plug wire from plug before inspecting blade area.
Apr 03, 2016 | Ferris IS2500 52"" Zero Turn Lawn Mower...
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Mower Engine shuts down when cutter engaged
With the spark plug wire(s) disconnected, tilt the mower and try to turn the blade. The blade bearing may be seized. Do you hear the belt screeching ? That would be a good clue.
Mar 07, 2015 | Garden
I own a Toro model 20070 mower with a Tecumseh engine. It's 8 yrs old. I have regular maintenance conducted. The mower starts and runs well but about 20 minutes into mowing, when I shut it down to empty...
Are you sure there is oil in the machine?
Are the Fins on the engine clean and not loaded up with sand and mud?
Sounds like it is running so hot that it is seizing.
Aug 06, 2014 | Toro Garden
Engage blades engine shuts down
if you removed the seat and then placed a fuse in the plug for the saftey switch and then started having this issue . with my experience with the safty switches on the seats most are open as not connected to make a circut when your sitting on the seat or pressure is applied to the seat . try removing the fuse and attempting to start mowing or least ingauge the blades and that should fix your issue ... when removing the origonal seat you just left that curcut open so it can not close and make connection when you get off the seat . so you should be fine after removing the fuse from the socket .. happy mowing
Nov 07, 2011 | Craftsman Garden
I started mower in tall grass. It started up and immediately stopped. Could not get it started. Replaced battery. Charged 12 hours. Still will not operate. Green light is on. Noticed the blade seems to...
After charging the mower, you must place the safety key in the mower before it will start. On models that have a bail handle, be sure to pull the bail handle back to the mower handle before engaging the start lever. If your mower still does not start, remove the safety key and ensure the bail and start lever are in the "off" position. Then firmly re-insert the safety key, pull the bail handle to the mower handle and engage the start lever.
Note - It is important that the bail and start lever are returned to the "off" position before inserting the safety key.
Give it try, if it still will not operate you may have to take it in for service.
Good luck, let me know.
Regards,
Jul 30, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
322 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
