Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
Changing belt How do I do that? It looks like I would have to take the screwdriver to the bottom and enter the engine compartment. I'm not sure that I feel confident to take this machine all apart and be able to get it back together again.
  • mitchell2704 Jul 07, 2008
    We've burned through three belts in a couple of weeks - is there a different problem that might be causing this?
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Its not the engine compatment take the screws out the cover 4 the roller will come off then u can c where the belt goes
Posted on Mar 30, 2008
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
Hoover cleaner model u5057-930
Hi! Below are step-by-step instructions on how to change the belt on your U5057930.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide. Hope this helps. If you have further questions feel free to reach out to us hear on Fixya!
HHdedd
Aug 02, 2014 | Hoover Vacuums
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
Belt
You probably need a phillips screwdriver to Remove the screws on the bottom of the vacuum and pull the brush bar out _ the belt is wrapped around one end of that and anchored to the vacuum - put new belt on and replace cover on bottom by replacing the screws.
Jul 25, 2013 | Kenmore Vacuums
How do i change the belt on the eureka 4703D
Changing the belt is quite easy on this unit.
First, you will need a phillips screwdriver looks like the X. there should be 2 screws on the top cover, and then MAYBE one more there by the hose where it attaches to the base at the back. The top cover comes off and you have full access to the belt underneath.
Also, side note, once you have the cover off there you should see a black and yellow sticker near where the belt rides, and it will go into more details to changing the belt.
Nov 03, 2010 | Eureka Power Plus 4703D Bagless Upright...
Changing A Belt on Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656349
Generic problem for all Vacuums
Changing a Belt on Vacuum
Posted by cnjk on Jun 08, 2008
Can you give me directions on changing a shark Euro-Pro UV219CS vacuum belt?
Thank you.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Shark vacuum cleaner belt is a side driven belt and you need to remove the bottom plate and remove the belt and place the new belt on the pulley side of the brushroll and make sure the ends are the same, insert the brushroll and then use a belt puller or screwdriver with a bend on the end and then stretch the belt onto the motor pulley and the track it in a straight line, replace the bottom plate. If you need further assistance please fee free to contact your local vacuum cleaner dealer in your area. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Changing a belt
Take off the bottom plate, look in the bottom to see if there are any screw, could be 2 of them, then from the bottom there is a slot on each side of the top cover, using a flat screwdriver, insert blade into the slot and pry up to release the locking tabs. Belt # is 38528040. Put the bell over the brush roll, put belt thru opening and put atound the motor shaft, put back together.
Jan 22, 2008 | Vacuums
Changing the belt
there are screws in the bottom take out then use flathead screwdriver on the side pry apart should cum off
Sep 11, 2007 | Dirt Devil M086365 Bagged Upright Vacuum
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
162 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
