Question about Fuji FinePix J10 Digital Camera
The flash isn't working. - Fuji FinePix J10 Digital Camera
My nokia x6 camera flash isn't working anymore, i restore factory settings then the flash of the camera isn't working... plz help
This can be a hardware issue, failure of the circuit, the flash unit or the LED. In this case it is best to take opinion and support from Nokia care unless you are fully equipped to open and check and evenso the spare could be another issue.get estimate and proceed
Jun 28, 2012 | Nokia X6 16GB Cell Phone
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Aug 19, 2011 | Nikon N75 35mm SLR Camera
I replaced the lamp now the lamp light on the frount of tv flashes yelow and tv does not turn on
The flashing yellow lamp light is indicating that the lamp door cover isn't installed properly or isn't contacting the door switch .
Aug 12, 2011 | Mitsubishi Televison & Video
My flash isn't working, I read the manual and did everything it said. Still nothing. Any suggestions? I'm new to any camera other that a point-and-shoot.
"My flash isn't working, I read the manual and did everything it said."
Hmmmmm .....
What does the screen show?
Is the camera on AUTO?
Last resort I guess is to go where you got the camera and ask them.
Jun 16, 2011 | Fuji FinePix S2 Pro Digital Camera
I cannot get the flash to work?
Most of the time, cameras have a small button located on the top, or near the other buttons that enables the flash. If there isn't one, try looking in the options for a flash setting and enabling it.
May 04, 2011 | Praktica SlimPix Digital Camera
Isn.t working...clock is flashing
I assume that you mean the oven is not working. The electronic timer needs to be in the manual mode for the oven to work. If it is flashing it means that it is not in manual mode.
Feb 15, 2011 | Kitchen Ranges
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Fuji FinePix J10 Digital Camera Logo
23 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
