Question about Acer Aspire E380 - Athlon 64 X2 4200+ 2.2 GHz (S6479431) PC Desktop
I have an Acer Aspire E380 desktop. Does it
I have an Acer Aspire E380 desktop. Does it matter which usb port I plug the router adapter into? There are 4 on the front and a slew on the back. Am unable to locate the user manual.
  • Anonymous Mar 17, 2014
    acer e380 desktop Cooling Module
  • 221 Answers
It should not matter as long as the antenna is not surrounded by metal.
Posted on May 08, 2010
Which usb goes where in the back of tower
any usb in any usb port
the computer sorts it out
wireless router has a special size plug and will only go in one hole
Sep 30, 2016 | Acer Aspire X1430 Desktop Computer
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
How do I remove the front panel of Acer Aspire ASE380 desktop computer? They are not working.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Cant get wireless to work on acer aspire ax3400desktop
Is it set up to be wireless? Is there a wireless card installed inside the desktop or are you using a wireless device that you use in one of the usb ports? Do you have a wireless router? Now that we've covered the basic requirements let's see if we can find a solution. Most desktops don't come with the ability to connect wirelessly out of the box. Normally you have to installed a wirelesss device either by using a pci wireless adapter that you istall inside the computer or a usb type adapter that you plug into a usb port. No matter which type you use you should have been given a software disk that contains the driver and the utility that controls the wireless device. You can connect either using the wireless utility software that should be on your desktop or under your programs list. Or you can connect using windows (windows comes with the ability to connect wireless once an adapter is installed) zero config. Normally your wireless utility software will have an option to either let it control your wireless connection or to let windows control the connection. I would try both options if I were you. Make sure you can see your wireless router in the list of available wireless networks. Find your network and click Connect. If it requires a password it will prompt you for it. Now if you notice your connection just continously polling trying to connect that means you put the password in wrong. You will never connect if you don't put the password in exactly right.
Mar 18, 2012 | Acer Aspire AX3400-U2022 PT.SE202.007...
Shut down my computer aspire e380 then disconnected the monitor from the computer and power to move it. reconnected the monitor turned the computer back on and monitor says no signal.
make sure all the plugs are plugged in snuggly turn off the computer again then turn on the screen. next power on the computer. if that does not solve the problem you may have an issue with the video card.
Jan 06, 2011 | Acer Aspire E380 ASE380-UD500A PC Desktop
Acer Aspire E380 won't start. When powering on the cpu fan runs at high speed but nothing else operates. Disc drive etc.
plug out the power cable connected in your CPU and replug it again still its not working you need to change the power cable
Dec 19, 2009 | Acer Aspire E380 ASE380-UD500A PC Desktop
Last Attempt to resume the system failed
try plugging a external rom into it and boot win xp from it it might take to that
Sep 18, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 01, 2009 | NetGear DG834G Router
Motherboard not recognizing usb Ports
chk in your device manager if they are blocked or not. control panel and then open system and hardware and then device manager scroll down and see if you have any USB marked in Red if its there then right click on it and enable it. if still fails try doing a system restore or you should need to install a new version of windows. that's the same issue i encountered and i end up in reinstalling a new version of windows. cheers !!! :)
Mar 26, 2009 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
2 SET OF SPEAKERS WON'T WORK FOR ACER E380
Do these speakers came with the system? If yes then check your manual from the Acer's website ( www.acer.com)
Also what color ports do you have in the back of the Desktop?
I believe you have a green, a Blue and a pink port, the Green is for outgoing sound, the Blue is for incoming sound, like a tape player recorder or a External CD player to get sound to your PC, and the PIN is the Microphone.
Feb 11, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire E380 - Athlon 64 X2 4200+ 2.2 GHz (S6479431) PC Desktop Logo
177 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
