Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
TV is turning off
I have a LTV32w1. It shuts off after about a hour and the blue light on the bottom that comes on when u turn the tv on turns yellow. Also the picture has a green tint.
  • 125 Answers
SOURCE: picture goes off with blue light still on.
It could be some hardware failure. But lets be optimistic. Try to reset your TV-set to the manufacturers default state. Not sure about the exact procedure but it must be fownd in the "menue", somewhere under "Settings" or "Channel search"!
Good Luck
/SciPhinx
Posted on Jul 11, 2009
cirocpatel
  • 524 Answers
SOURCE: got new tv Westinghouse LTV-32W1 32 Inch
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
Posted on May 11, 2010
budmrtn
  • 11361 Answers
SOURCE: tv doesnt come on
You may have power supply module problem or short circuits in the inverter board, those are the two areas you need to check.
Right now the 5vdc standby is working but nothing else.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Westinghouse+LTV-27W2+&limit=100
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Posted on Jul 29, 2010
  • 8457 Answers
SOURCE: tHE tV GOES BLANK WITH
Power supply board is going.Not giving the right voltage to the tv anymore.That why,power it is not consistance.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 26, 2010
budmrtn
  • 11361 Answers
SOURCE: LTV32w1 - powers up, indicator goes from blue to
You need to remove the base and lay it down flat on a soft surface and remove all the screws on the back and pry open the back. Look for cold joints, the one in my pictures has cold joints on the one of the leg of retangular grey cap. I would usally inspect the board real well with magnifying glass and resolder just about all joints just to sure.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Nov 13, 2010
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
Sep 22, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Wd-73737 wont turn on blinking green light
First is if you are able to get it to turn on and blue screen only appears it will shut down as no signal noted.
If you can get it on with Mitsubishi remote : Menu, 1,2,3 enter
This is the soft reset and the set also has a hard reset.
Try the soft reset first and let me know what happens.
Mar 09, 2012 | Mitsubishi WS-55613 55" Rear Projection...
THE tV GOES BLANK WITH NO SOUND 5-10 MINUTES AFTER TURN ON. The blue pilot light in front stays on and sometimes goes yellow . The Tv will sometimes work again if I turn it off and them back on.. Model...
Sep 26, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
