Question about Refrigerators
Water is leaking from refrigerator forming pools of water on floor.
  • 555 Answers
You need to pay attention where the water is coming from. If the water comes from doors, look for magnet seal broken or spills from the inside the fridge. If the water comes from the bottom (or back) of the unit, it may be an installation issue.
Once you locate the source, it will be easy to fix.
Posted on May 08, 2010
Lately there is a pool of water forming under and in front of the refrigerator . what can we do. It is a side by side Jennair?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 12, 2011 | Jenn-Air JCD2389G Side by Side...
Pool of water constantly forming on floor at front right corner of fridge. Can't identify where it's leaking from. Door seals are new. Fridge and freezer operating well.
Make sure there is no lint or dust in the fan motor located on the lower back of the fridge. If you clean the fan of lint and dust it should help evaporate water in drain pan.
Jan 02, 2011 | Refrigerators
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Water leaking on the floor
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Jun 03, 2010 | Jenn-Air JCD2290HES Side by Side...
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
