Question about Zebra LP 2844 Thermal Printer
It doesn't print anything!!
I 've tried too much to print on a label but it didn't work!I don't know what else to do maybe it's the thermal head broken but the spooler works fine if you put the right parameters of the label!!Everything is working perfect but it doesn't print!!Any ideas guys???
    Problem Solver:
  • 7 Answers
Yea i already solve this problem!!It was my miss because the person who gave it to me missed to tell me that he changed the paper of the printer,because thermal printers need a special thermal paper!!It was my fault not checking it from the begining.Beleive me it seemed (the paper) so right and i had to check it with a lighter!!So thank you for your interest and i'm waiting news when a problem ,that i can help, come up!!!
Posted on Mar 28, 2008
SOURCE:
Printer only printing on part of paper When I changed the tape, only the left third of the receipt printed
check your paper rollerand gear first, it is attached to the paper cover. if the roller and gear is good condition your thermal printer maybe bad or dirty. you can try cleaning the thermal head. get a piece of thermal paper fold it. rob the paper on to the thermal head. do it 2 or 3 times with a clean piece of paper. then try printing again. if if doesn't work. call (775)358-2922 look for randy and maybe we cal help. thanks
Sep 17, 2011 | VeriFone VX510
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
When adding the Dymo labelwriter 450 turbo to Windows 7 machines, the installation completes fine. When attempting to print, an error shows up in the device manager that says Access Denied for the print...
i HAVE LABEL WRITER 450 TWIN TURBO AND I CAN NOT PRINT RETURN ADDRESS LABELS. i HAVE UNINSTALLED AND INSTALLED AGAIN THAT DOESN'T WORK THE RETURN ADDRESS LABEL IS THERE IT WON'T LET ME TYPE ANYTHING IN THE SPACE PROVIDED IT WAS WORKING FINE THEN THE NEXT DAY IT WAS NOT
THANK YOU
Aug 19, 2011 | Dymo LabelWriter Thermal Printer
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
Dear Sir, Madam, We recently installed our Zebra S600 labelprinter together with the Zebra Designer software. But the labelprinter doesn't print out our labels. We've searched the internet and...
It sounds as though it is printing test labels. Switch of and on again to reset.
If no change then try factory reset.
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
Jul 06, 2011 | Zebra Stripe S600 Thermal Label Printer
I have the zebra lp 2844 i'm trying to print from ebay everything is working ecept when i print the label only two line print. i did a test page and it comes out fine i have calibrated the printer and...
Check that your printer setup software is "setup" correctly (AKA printer properties in "control panel" or "devices & printers").
Look at the "label size" and orientation (portrait or landscape) in the printer setup, that may be wrong and cutting off the rest of the printout. If you indicate more printer buffer size that what there is, that to might cause problems.
Other things to check for: Do you have the correct print driver for your OS?
Make sure you have the correct printer selected in Ebay. I don't use Ebay to print labels out with my thermal printer, but I use paypal and I believe they are very similar if not the same. Also, in paypal anyways, you have to have the correct run-time version of JAVA installed in order for it to work properly. Don't know about ebay, but that might be something to look into.
Jun 15, 2011 | Zebra LP 2844 Thermal Printer
My Brady LabPal label printer seems to be printing labels that are not very bold and, in fact, the numbers are often only half printed. Do I need to change the ink cartridge within it, or what is the...
I have label cartridge in but it doesn't print, just says "insert labels". I have tried many times to take cartridge out, and reinsert, but it won't do anything.
Jul 01, 2010 | Brady LAB PAL Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Nov 12, 2008 | Zebra 105SL Thermal Label Printer
Zebra 2824
if you see that it is like printing a card. check your thermal print head maybe its not working.
Jun 23, 2008 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
82 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
