Question about GE Profile Harmony DPGT750EC Electric Dryer
My ge profile dryer won't start.I checked the breakers and they were ok. Any other suggestions?
    President:
  • 1,382 Answers
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
Posted on May 08, 2010
2 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: GE Profile Model#DPSB513EBOWW Breaker kicked to
Have you reset the dryer breaker also. Even if doesn't look tripped turn off then back on again.
Posted on Feb 01, 2010
Will not power up
OK you have power but, is it 220 volts. If you check that with a multi meter and have 220 volts then we can go from there and check other stuff. I am waiting to help you
Jan 28, 2014 | GE Profile Harmony DPGT750EC Electric...
Display won't turn on
Check breaker panel. Check voltage to back of unit. If both ok then likely need a new display.
Jan 11, 2014 | GE Profile Harmony DPGT750EC Electric...
GE DPSE810EG won't start
You will need to check and see if the dryer has a bad thermal fuse on it. If so, it will cause the dryer not to start.
The thermal fuse should read closed for continuity. The thermostat is number 507 on this diagram. It is located on the top of the heating element housing.
Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | GE Profile 7.0 cu. ft. Electric Super...
I have a GE profile performance wisard dryer. When I press on the start/pause, the light just blinks and the dryer does not turn on. I have turned the dryer completely off, unplugged it, checked the...
Take the cover off where the power enters the dryer and confirm that you have 240 volts there and the connections are tight. If yes, check for a broken belt or a drum safety thermostat. The last time I saw this, I found incorrect voltage present at the dryer. Checked the breaker and found that there was a bad connection from the breaker to the main buss bar in the circuit breaker panel.
Feb 05, 2011 | GE Dryers
My GE profile model dpgt750ec dryer will not turn on - checked breaker okay, light comes on inside the door, but no power when attempting to turn on
Recheck breaker turn the breaker all the way off and then reset the breaker. Then try a different cycle. like air only or something different than you normally use and see if it works then. Motor could be out or The control switch. Make sure you are looking at a double pole 220 breaker. hope this helps.
Dec 19, 2010 | GE Profile Harmony DPGT750EC Electric...
Feb 01, 2010 | Whirlpool ET8CHEXSQ Dryer
DRYER PROBLEM
my dryer shut off one day and will not start up I reset the breaker switch and no luck
Oct 06, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
411 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
