Question about Whirlpool Washing Machines
LAST SPIN SOUNDS LIKE LAWNMORE, IS THA NORMAL
LAST 5 MIN SPIN SOUNDS LIKE LAWNMORE MOTOR, IS THAT NORMAL.
  • 141 Answers
It may be due to heavy usage or water leak at the bottom of the unit if you find any water leak kindly replace the two inner bearing along with the water seal top solve your problem
Posted on May 08, 2010
Maytag neptune mah5500b sr code
Machine control is attempting to drive the motor but is not seeing any tach response.
Visual check shows motor is not moving. (Locked, Hall Sensor fault).
Evaluate wire harness for loose or unhooked connections.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Cooling Fan Spinning Fast On A Cold Start
most fans are clutch fans and they work or are engaged by temp.most all will spin under really cold conditions.this is normal.but to be sure, with the motor off and key in your pocket grab the fan and see if it wiggles or has any slop. if not alls good
Dec 20, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
My duet front loading washer has a code 06. When I turn off and unplugged for 1 min. then tried to start it again, it started filling with water then stopped and started beeping the code again. I did this...
This is a Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Make sure the wash load is not too heavy and do not move the washer when it is powered on.
If the error persists then the normal process is to check the following:
  1. Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
  2. Check the Drive Motor.
  3. Check the MCU
  4. Check the Wire Harness
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Starts rought,drives and sounds like a lawnmorer?
The most likely cause is water allowing secondary (spark) voltage to go to ground. Look at all plug wires. Inspect carefully the inside and outside of the distributer cap...
Sep 09, 2009 | 1985 Mercedes-Benz 190
Washer failed to spin.
yeah ...most probably but could also be the tanssioner thats broken!
belt is a joke to replace
Jul 21, 2009 | Samsung WF337AA Front Load Washer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
