Question about Samsung AW1203B Air Conditioner
My unit is throwing off my breaker. Need to know
My unit is throwing off my breaker. Need to know what the problem could be?
  • 674 Answers
You possibly have a ground, either a fan motor or compressor motor or a loose or cut wired. You could also have a motor that is locked up. Either possibility is not good.
Posted on May 08, 2010
Outside ac unit breakers keeps breaking
Check all wiring for loose connections, particularly at contactor. Check for short circuit and earth leakage
Apr 21, 2012 | Heating & Cooling
A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
May 15, 2010 | Coleman Mach III Air Conditioner
Everytime my heat kicks off it throws the breaker then i have to reset the breaker.heat runs for awhile then kicks breaker again
need to check amp draw to blower motor if indoor unit.
if outside may be several things need a pro!
Oct 27, 2009 | Intertherm Heating & Cooling
My problem with my AKT3650 is the unit sparked and threw a breaker at only one control. Even turned off the unit will throw a breaker and spark. I was thinking it was just one of the switch components -...
So doing anything will throw the breaker? Must have a shorted wire either going to ground on the cooktop of where the cord wires in at the cook top. Dont know exactly but be looking for wiring with insulation gone and rubbing the frame or each other
Sep 03, 2009 | Amana AKT3650 Electric Cooktop
Throwing breaker
Throwing the MAIN BREAKER should not happen. Calculate the distance to your main box. Tell me the wire gauge or breaker amperage. Whatever you do, do not get a larger breaker! If its a breaker on this unit Its probably doa with current leak possibly. DO NOT USE fire hazzard IF SHE TRIPS!!! let me know if its your main breaker inthe house. Hopefully you dont have crappy cloth wiring.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Throws breaker when turn oven on
is it a new larger stove,then it could be a power supply deficiency,otherwise an element is bad or shorting to unit case and causing a trip
Aug 14, 2009 | Frigidaire FEF375E Electric Kitchen Range
Throwing Breaker
you could have a couple of reasons.If you use an extention cord that is too small,If the circut is overloaded.Bad breaker,good luck!
Jul 08, 2009 | Coleman Propane Forced Air Heater...
Roof Top A/C Throwing Main Breaker
do you have an amp meter. when the main is tripped what is running? maybe the main breaker is going bad. I dont think you are pulling more than 20 amps when everything is running. not unless the fan on the A/C shorts to ground when it gets hot????
let me know
Jun 22, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm 13500 btu
First I would check the size of the power supply cord to the coach. To small a line will cause a voltage drop which in turn will cause the amperage to increase. Check the supply voltage to the system.
Jun 16, 2008 | Dometic Rooftop RV Air Conditioner
Breaker keeps throwing
jhweis80 Why do you think the problem is the dryer? The circuit breaker itself could be bad and this is what I will check first. Probably you need a professional electrician to do it for you. Gendos post back...
Jun 27, 2007 | Maytag Neptune MDE6700A Electric Dryer
Samsung AW1203B Air Conditioner Logo
81 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
