Question about Crescent Rod The Rod - 5' Curved Shower Rod/Color=White
Crescent rod installation into a acrylic walled shower/tub unit. instructions say differant hardware needed but not included,consult contractor or hardware store for installation.
  • 26 Answers
You will need to seal any holes made in your acrylic walls inside your bath unit. When installing the brackets to the wall, try using a piece of rubber (pre-cut for a custom look) between the acrylic wall and the bracket mounting hardware. Be sure to seal everything with a clear latex caulk that is designed to resist mold.
Posted on May 16, 2010
What adhesive should I use when I install my acrylic shower walls
here is a how to including supplies:
http://www.homedepot.com/c/installing_shower_walls_glue_up_HT_PG_BA
Oct 25, 2016 | Home
What adhesive is recommended for use with a max acrylic shower wall
the adhesive used is alkaline free so go to a plumber supply shop that sells bath and shower stalls and get the correct adhesive
it is a special type that comes with new installations
Oct 25, 2016 | Home
I had just bought a neo round 32 inch acrylic shower base and had a plumber install the base.. Unfortunately, while installing some drywall in the bathroom, one of the installers managed to create a small...
Depending on your level of skill and desire to have an invisible repair you have a few options. From easiest and worst looking to harder/expensive Use a marine epoxy, like marine tex or super mend. This could look Ok depending on your skill you can get an acrylic/fiberglass repair kit. or you could get someone who fixes hot tubs and bath fixtures to do it
and hire a better class of drywallers :)
Aug 11, 2011 | Maax Acrylic Base for Shower - 102623
My contractor installed a 4 port diverter. The hot and cold are ok, but when I turn the shower on, the flow starts in the hand held shower head and not the main shower head. According to Grohe, whichever...
I haven't had a lot of experience with Grohe brand but have had twenty eight years as plumber, 22 years as master plumber and the bottom port of every tub or tub/shower valve that I installed used the bottom as main supply port. As far as the instructions from manufacture like I said I have not used that particular brand much,so I really couldn't say. Hope this helps some. Thanks
Nov 10, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
We have a new shower. Water comes out of shower head and tub faucet together. What do I need to do?
its because that model usually when u pull for the shower is not properly connected. You will have to remove handle and coverplate, then shine flashlight down to see what is happening when pulling rod on tub spout for shower. Usually its broken or bent and just needs new one installed. It cost me 2 buck for new shower rod. Directions u can get free from Moen with free lifetime parts.
Oct 06, 2010 | Moen & One Handle Tub & Shower Faucet
Just had a contractor give me an entire new bathroom. The Peerless Single Handle Tub And Shower Faucet will only go from 90 deg down on the cold side to straight up. it want go to the hot side. What is the...
if u have the paperwork for the unit--in it will explain how to adjust the anti scold settings single handle units are shipped in cold setting u have to adjust the hot -- remove handle and on shaft will see blue and red clips adjust the red till hot water is to ur liking replace handle
May 18, 2010 | Peerless Industries Peerless& Single...
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Why do they say not to mount the curved shower rod on acrylic. Our tub is a three piece so there is nowhere else to attach it.
Mount it above the top of the plastic walls. If you try to attach it thought he plastic, it will eventually twist out of the plastic.
Jul 12, 2009 | Audiovox Bath Unlimited D190-5W Curved...
Need electrical schematic for Ariel 701 steam show/jacuzzi tub
What I recommend to you is to contact a supplier that handles these units. They might be able to contact the vendor for the product to try and get more info for you. To be honest, I think your electrician is being a little unreasonable. I would consider finding another electrician. I realize he doesn't want to miswire something and then have to replace it but it would take a complete knuckle head to mess up the wiring on a motor. My opinion though!
Apr 08, 2009 | Dmm WMK-A06 Pearl Steam Shower Unit,...
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Crescent Rod The  Rod - 5' Curved Shower Rod/Color=White Logo
256 people viewed this question
Top Crescent Home Experts
john h
Tom Chichester
Are you a Crescent Home Expert? Answer questions, earn points and help others
