Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
I am moving, and need to put a pin in my washer and dryer
I am moving, and need to have my front load washer and dryer (LG Trom) moved. I know I am suppose to do something with a pin to stablize it, put I don't know what/how to do it
  • 1294 Answers
SOURCE: need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 21, 2008
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 489 Answers
SOURCE: LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Posted on Jul 23, 2008
  • 7 Answers
SOURCE: LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Posted on Jan 22, 2009
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
Posted on Feb 01, 2009
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
I have an LG washer dryer (model 12126rd) and it has just cme up with either UE or VE on the frint LCD panel. What does ths mean? Thanks!!!
UE means imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Resolution: Move the washing around inside the washing machine to create a more even distribution of weight
Oct 25, 2009 | LG WD-12126RD Front Load Washer / Dryer
Missing shipping bolts
if you are moving and you are using a dolly to move it than you dont need shipping bolts. i del. preowned washers and dryers everyday and never put shipping bolts back in just becareful and use your head and you will not hurt anything.dont bounce it down stairs either it is a 2 person job so dont forget to get some help
Jan 30, 2009 | LG WM-2077C Front Load Washer
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
Jul 22, 2008 | LG WM-1832C Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
235 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
