Question about Bose 3 2 1 GSX System
Sount Skipping I agree with all that the Bose 321 is full of problems. Here is mine. The sound intermitntly skips, or goes on an off. At first it seemed like this happened only at higher volumes, and only when playing a CD. Recently, I suscribed to Direct TV HD, and now it happens with the TV too. I am not very technology savvy. Here is my question. I have found just the 321 reciever/player on the internet at a relatively cheap price and am willing just to replace this and keep the speakers. I suspect it is the receiver/player and not the speakers, but would hate to buy this and find out it is the speakers. Can anyone assure me that it is the reciever/player and not the speakers?
  • 4,102 Answers
Hi this is a common problem with that device the speakers are fine and will not be causing the problem have you checked all the wires are in the right way round like the + and - as this can cause the problem your having.
If the wires are correct then the chances are its going to be the amp thats damaged probably a blown resistor causing the volt to fluctuate it shouldnt cost to much to get repaired.
What caused the problem is going to be having the volume up really high then a load of base running through the amp this can cause internal parts to fail so this is the likely cause.
If you are to replace the base but keep the speakers then make sure the base and speakers are the right power or else you will have bad sound and also could affect the surround sound quality so just check the watts are the same and you should have no problems.
Let me know if you need further assistance ok
Posted on Mar 27, 2008
  • paul proctor Mar 27, 2008
    Just make sure you double check the output form the base your going to buy matched the speakers.
    But before you replace check all wires are correct and also what is the base plugged into dvd player or tv etc let me know ok as this could be also the route of the problem let me know then i can help your further ok
  • 3,037 Answers
Try the speakers with another tv, hook them right into the back and verify that they are the problem but my best bet is that it is not the speakers and rather the system. Good luck and if you have any further questions, please let me know, thank you.
  • Benjamin Patri
    Benjamin Patri Mar 27, 2008
    seeing as all of the speakers skip the sound, the speakers being the problem is very unlikely.
6ya staff
SOURCE:
My Bose stereo CD player skips when I put on a cd. Doesn't matter if I change cd or advance track. After 5 min. it stops skipping, then no problems until next time I turn it on.
Bummer deal! Sounds like a lube problem. Maybe its an age thing. My car player does just the reverse. The arm hinge is the problem. Try wd40 with a straw, sprawing into the disk area, using a cd you don't mind losing to see if this tip works. http://www.auto-tune-up-and-repair-options.com/Mega-Power-120-lube-spray.html
Dec 05, 2016 | Bose Audio Players & Recorders
Bose 321 series II giving very dull sound in all inputs. Occaisionally the sound cuts and comes back with full and bright trebble, but then cuts back to original dull sound. I cant see anything the ad
Try the following:
1) Switch the unit off completely, using the powerswitch on the back of the bass box.
2) Switch the unit back on via de switch on the bass box.
3) The display should read BOSE 321 and than be dark.
4) Insert a CD and switch the unit on with the remote by selecting the CD/DVD mode.
5) When the sound is now OK, it means that you need to contact Bose to ask them for the latest software update for your unit. After updating your system. The problem will not reoccur.
6) in case the problem continues and at start-up using a CD, no improvement of sound is heard, the system should go into repair. Contact Bose in your country and ask for return instructions.
Jan 13, 2014 | Bose 321GS Series II System
I have a Bose 321 GS Series II. It's about 5 years old. After about 45 minutes, the sound becomes distorted. It gradually gets worse and worse. Turning the unit off for 10-15 seconds usually resets it;...
I had the Bose 321 same issue call 877-210-3782 they will set U up with shipping "email U the Labels UPS" If out of warranty total price which includes shipping to and fro is 191.28. Better than replacing at over 700 to 1000 bucks hope this helps.
Sep 05, 2010 | Audio Players & Recorders
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Apr 04, 2010 | Bose 3 2 1 GSX System
Bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Apr 12, 2009 | Bose 3 2 1 GSX System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
VOLUME ISSUE
I had my older bose 321 hooked up through vcr and sounded great. Then hooked it up through directv receiver and sounded better. then switched from direct to comcast and hooked the bose up throught the comcast hd receiver and the volume is aweful. same deal, have to crank it up high. Since the stereo built into the tv sounds so much better I disconnected the bose and am going to sell it.
Dec 28, 2007 | Bose 3 2 1 GSX System
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Problem with sound skiping on Bose Lifestyle 8
would not exactly agree with bose proposed solution, however easy to test......
borrow a dvd palyer of a different model and type , ensure that the output from the dvd player is set correctly ie. 5.1
you need to verify that the co ax you are useing is not damaged, faulty and is connected both ends correctly,
if bose give you some hassle get a spare set of cable to be sure the connect or to the co- ax is not damaged in any way.
lastly :
i suggest there is a problem with the on board decode for dolby 5.1, known as SPDIF = "S P diff " ( a system designed in conjunction with SONY and PHILIPS and used on nearly every 5.1 decoder sold in the world) easy to fix its usually a firmware upgarde or reset usually done in the factory, simple problem, could have been caused by electrical interference or unusual magnetisim problem post manufacturing or possible on site problem, however from your point of view impossible to prove either way.
must point out that analog cables don't carry a 5.1 signal. and also should point out that co -ax is not 100% necessary nor the only way to push a 5.1 signal into that bassbox.
check your cables first , then borrow a dvd player, then bring it back to bose and tell them to fix it. if its still wrong.
Oct 10, 2006 | Bose Lifestyle 8 series II System
Bose 3 2 1 GSX System Logo
152 people viewed this question
Top Bose Audio Players & Recorders Experts
Ben Armstrong
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
